OSX Mavericks and Yosemite on Intel pentium t2370
Nxtlinyo
43
AMD Athlon II X2 270
Hi, I managed to get both osx version boot into recovery but I have a problem which lan and wifi card won't work, can anyone help? Lan: marvell Yukon 88e8039 pci-e fast Ethernet controller wifi: Intel pro/wireless 3945abg and totolink n150ua USB wifi card
For the Marvelll LAN issue see this old post over at InsanelyMac.
You basically have to add the Device/Vendor ID for your LAN controller to Info.plist in the kext.
Not sure either of the WiFi devices you listed above are supported in OSX Mavericks or Yosemite, as there was a distinct lack of non-Broadcom WiFi drivers available in those older versions of OSX. A few Atheros WiFi cards were known to work back then, but Intel was not possible.
See this Wireless buyers guide for details.
Which make and model Laptop are you using, or trying to use?
I had an old Dell laptop with a similar CPU that ran El Capitan, but it required a specific setup to get it working with OSX.
Compaq presario v3732tu
The Intel GMA 950 graphics are only supported in OS X Leopard 10.4 through to OS X Lion 10.7. So you may need to try installing an even earlier version of OS X than you want. As it is unlikely you will get graphics acceleration working in Mountain Lion or newer.
