[Help] Ryzen 9 9950X + ASUS ROG X870E-E Gaming WiFi | Stuck after "OC: Connecting drivers done..." | macOS Sonoma Installer | OpenCore 1.0.7
pvford55
15
United States - Texas, the humid part
AMD Ryzen 9 9950X
System Specification:
  • CPU: AMD Ryzen 9 9950X (Zen 5, 16 cores / 32 threads)
  • Motherboard: ASUS ROG X870E-E Gaming WiFi
  • RAM: 64 GB DDR5
  • GPU: AMD Radeon RX 6900 XT
  • Storage: (add your NVMe model if known)
  • Target OS: macOS Sonoma (installer from external USB)
  • OpenCore version: 1.0.7 (DBG-107-2026-03-20)
  • SMBIOS: MacPro7,1
Problem Description:
OpenCore boots to the picker without issues. When I select "Install macOS Sonoma (external)", it reaches:
"OC: Changed resolution to 1024x768@0 ..."
Then the screen goes black / no further progress — no Apple logo, no verbose macOS text, no kernel panic, no installer GUI. It hangs at this exact point.
The frequency message ("OCCPU: Failed to get FSBFrequency data using Apple Platform Info - Not Found") appears but I am ignoring it as requested — I only care about getting it to boot into macOS.
What I have already tried (current config state):
  • SSDT-HPET.aml disabled + its two renames disabled
  • SSDT-USB-Reset.aml disabled
  • SSDT-PLUG-ALT.aml still enabled (this is the next one I plan to disable based on advice)
  • SSDT-PMC.aml disabled
  • Boot-args simplified to: -v keepsyms=1 -amfi_get_out_of_my_way=1 (npci=0x3000 and revpatch=auto removed for testing)
  • Booter Quirks: DevirtualiseMmio=true, RebuildAppleMemoryMap=true, ProtectUefiServices=true, SyncRuntimePermissions=true
  • Kernel: DummyPowerManagement=true (in Emulate), ProvideCurrentCpuInfo=true, DisableIoMapper=true, XhciPortLimit=true, PanicNoKextDump=true
  • Kexts active: Lilu, VirtualSMC, WhateverGreen, NVMeFix, AppleALC, USBToolBox + UTBMap (others like RestrictEvents, AMDRyzenCPUPowerManagement, SMCAMDProcessor are disabled)
  • Full AMD Vanilla kernel patches (algrey cpuid_cores_per_package, commpage, cache info, mtrr/PAT fixes, etc.)
Attachments I will include:
  • Current config.plist
  • Latest OpenCore boot logs (opencore-*.txt)
  • SysReport.zip (contains ACPI tables, SMBIOS, CPUInfo, PCIInfo, GOPInfo, etc.)
  • Screenshot of the OpenCore picker + log when it hangs
What I need help with:
I need the system to progress past "Connecting drivers done..." into the macOS kernel / installer.
Any suggestions on which SSDT or quirk to disable/enable next, or any missing AMD Zen 5 / X870E-specific fixes would be greatly appreciated.
Thanks in advance for any help!
  • RAM: 64 GB DDR5
  • SMBIOS: MacPro7,1
Check this link for more insight, @fabiosun motherboard is different but you'll be able to narrow down what ACPI files you need. I'll mention your Booter/ MmioWhitelist values in your config.plist seem incorrect. You may not need any entries at all if you turn on DevirtualiseMmio in Booter quirks.
