Buenos dias, estoy probando crear un efi para instalar en un Ryzen 9 7950X 16 Core, Memoria 16GB, Placa Base Asus B650-PLUS, disco duro 1TB nvme y grafica amd RX 580 8Gb 2048.
El sistema os que estoy intentando instalar es el Tahoe, pero se queda a mitad y no pasa de ahi. Algun consejo. Gracias.
Good morning, I'm trying to create an efi to install on a Ryzen 9 7950X 16 Core, 16GB Memory, Asus B650-PLUS Motherboard, 1TB nvme hard drive and amd RX 580 8Gb 2048 graphics.
The system I'm trying to install is the Tahoe, but it stays halfway and doesn't go past there. Some advice. THANK YOU.
I attach my EFI file.
Please post in English.
Por favor, publique en inglés.
Your RX 580 2048 GPU isn’t natively supported by macOS. You may need a patched VBios for the card before it is seen and works correctly with macOS. See this thread over at Tonymacx86’s regarding the dGPU.
Which NVMe drive are you using, not all NVMe drives are compatible with macOS, as they use Phison and other non Mac friendly controllers.
I will have a look at your EFI folder when I am at my desk, later today. But without the information requested above regarding your NVMe drive, I am not sure if your issues are solely related to the EFI configuration.
