USB audio stutters
adebahia
Ryzen 5 5600
I don’t have a working internal sound card, so I’m using an Aiyima A2 DAC with my speakers connected to it. For headphones, I’ve been using random USB dongles (Ugreen, Essager, Orico), but all of them have minor stuttering issues. It’s constant and sounds like the audio is buffering, even when playing local files.
Recently, I bought an original Apple USB-C to 3.5mm adapter (purchased directly from their website) and plugged it into a USB-C port on my motherboard. Same issue — crackling and stuttering.
The weird part is that the Aiyima A2 works perfectly (it’s powered by a 5V charger). I’ve tried pretty much every tutorial I could find:
Tested all USB ports
Switched PCIe between Gen 3 and Gen 1
Disabled SVM
Disabled serial port
Changed sample rate/bit depth
Disabled XMP
Regenerated the USB port map (USBToolbox and USBMap)
Created a new EFI from scratch
Changed SMBIOS from MacPro7,1 to iMacPro1,1
Downgraded from Tahoe to Sequoia and even Monterey
Nothing changes.
Does anyone have any idea what could be causing this? I’m starting to think there might be some issue with Hackintosh USB implementation, but it’s really strange that only USB audio dongles are affected.
Specs
CPU: Ryzen 5 5600
GPU: AMD Radeon 6700 XT
Motherboard: Biostar B350 GT5 (latest BIOS)
RAM: 2x8GB 3000MHz
No WiFi/BT card
Try using the USBMap or USBPorts.kext to configure your USB ports. The USB SSDT would require a working USBInjectAll.kext, one that works with your AMD USB Controllers, which I don’t think exists.
Then maybe you need to look more closely at the connector types you are associating with each USB port. As USBMap.kext works just fine in Tahoe and earlier versions of macOS, as long as the discovered ports are set correctly.
The associating is correct, it's the same in Windows. I only have problems with audio dongles. I've tried using a USB hub with a 5V power supply, like my Aiyima A2 (which works fine), but it still stutters.
