RX 570 8GB - Whatevergreen, NootRX or agdpmod=pikera?
alliance
5700X
Hi,
which is the best to use with an RX 570 8GB, in Tahoe?
Whatevergreen or NootRX, or do I simply need to use agdpmod=pikera?
Hey!
If I'm not wrong, agdpmod is only applies when using WhateverGreen. NootRX doesn't require any arguments to work, and it's a better option for Tahoe right now.
Reactions: alliance
Hey!
Hi :)
So if I'm already using NootRX on a RX 6XXX series on Tahoe, can I simply change the GPU to the RX 570 8GB and it'll boot up fine without any config.plist changes?
When using an RX 500 or RX VEGA series GPU you are best served using WhateverGreen.kext.
You do not need to use the agdpmod=pikera boot argument with the RX 500 or VEGA series of AMD GPUs.
NootRX.kext is solely aimed at the newer Navi ll series of cards (RX 6000 series).
NootRX includes the agdpmod=pikera boot args, so it is not necessary to have it in the config.plist when using this kext and a compatible GPU.
Thanks.
So just delete NootRX, add WhateverGreen to the kext's folder, do a Clean-OC-Snapshot, save, and reboot with the 570 fitted?
What is the different between a OC-Snapshot, and a Clean-OC-Snapshot? I always wonder if I'm using the right one :ROFLMAO:
Use the Clean OC Snapshot, which will update your config.plist with the revised contents of the ACPI, Drivers, Kexts & Tools folders.
The other OC Snapshot option creates a new/separate config.plist that contains entries for the contents of the OC folder. Helpful when you want to compare entries used in different OC setups.
Reactions: alliance
