Hi have a problem booting to installing sequoia Solved
xmax114
7
3700x
Hi been trying for a few days now to figure this out but every time I boot on my laptop I always get this error did try looking it up but it never got me anywhere even tryed redoing my efi from scratch still getting the same problem any help with my efi would be great my specs are below also attached some pictures and my Efi
  • CPU: Ryzen 3 2200u
  • GPU: Radeon Vega Mobile Gfx
  • RAM: 8 GB
  • SanDisk SD9SN8W: M2 128GB
  • Audio Device: Realtek
  • macOS Version:
  • SMBIOS: MacBookPro16,3
  • OpenCore Version: 1.0.6
  • config.zip
    config.zip
The screen images above say that you have issues with the USBToolBox kext and HPET SSDT in your OC setup. Neither seem to be loading/working correctly.
  • RAM: 8 GB
  • macOS Version:
It would be good to know what version of macOS you are trying to load. Also is it weird the AMD Vanilla patches lowest core count is 4 but you only have a 2 core processor (which you accounted for in the patches). Usually if core counts are wrong in the config.plist it will stop booting almost immediately so hopefully that is a non-issue.
Without seeing your entire EFI folder the other thing that pops out is WhateverGreen.kext. It will not work with your iGPU so best to try disabling it and see if it finishes booting. If it does then finish the install and after add in NootRed.kext which is what you will need for accelerated graphics. Reset NVRAM.
You can also try adding it to your EFI to see if it boots but often it has to be added after.
Well here is my EFI and I don't know what version Mac it is as i got it throught following dortania guid which just says lasted version
I did start again from scratch and made a new EFI from scratch which only gave me this error
Well I'll ask again what version of macOS are you trying to install? Ventura? Sonoma? Sequoia? Whichever one I explained Whatevergreen.kext does not work with your system but you are still using it.
I was using dortania said lasted version
I'm trying to install sequoia and i did realise that and removed but still gave me the same error
I finally fixed the problem and managed to get it fixed through the discord channel after someone trying to help me and we finally got it done
What did you have change?
Reactions: Edhawk
Had to remap my usbs with usbtoolbox and change the setting to use Native Classes to build usbmap and put in the kext folder and than removed both usbtoolbox and UTBMap as there not needed as you would have usbmap instead and also downloaded Ryzen-CtlnaAHCIPort kext and added it to the kext folder hope this will help someone else.
Hello xmax114. i have a lenovo laptop with the same processor. i made a usb with opencore simplify, but i can't reach the setup screen. i tried in catalina and monterey. could you send me your efi folder with your config to try it in my laptop?. i don't know what more to do.
