I am sure any comments about your EFI folder were meant to be constructive, not negative.
I will have a look at this later today.
Hi you should re-check starting from hereI have reached a point where I can boot into the installation section for Sonoma, but neither Disk Utility nor the Installer can see USB drives. I had the NVMe SSD drive attached via USB, mostly for convenience to move it to another computer. Once I placed it into the NVMe port, it worked and I am currently doing my first install.
However, I need information on how to set up OpenCore to see the USB ports on a ASUS ROG STRIX X870E-E Gaming WiFi.
If there are instructions regarding this, please let me know where they are located.
Thank you
PF
This message. You said you booted in SOnoma so you must start from here adjusting things from here I meanI have succesfully booted in to Sonoma but I have several post installation issues.
If this is the wrong forum please tell where to go, and also which forum is appropriate.
The most significant issue that I know of, is after a certain amount of time, the system tries to reboot. I suspect there is a problem with sleeping and hibernation that trigers this.
Less serious, but annoying, is that I never see the Apple logo with the scroll bar, so it looks like the system hung.
Also I need to work on my USB ports. Some that I like to work don't, but at least I got the USB-C ethernet adapter working so I can access the internet. Enlcose Config.plist and 2 of the OpenCore Debug text clean up to remove excess <nulls>.
Thank you
The DSDT is needed to investigate ACPI patches, but the patches in this post have been designed against Asus ROG Strix B650E-F Gaming, among other boards, so there's hope they may still work for a ROG Strix X870E-E Gaming. (How do they come up with these crazy names???)You miss an important part for asus motherboard (ACPI patches for bios done by CorpGhost or also @etorix if he has some time to do)
Yes some mess also in this EFISubject: Help debugging post-install black screen on Sonoma (Ryzen / OpenCore)
Hello again everyone,
I've reached the point where I can successfully boot the macOS Sonoma installer, complete the installation, and after several reboots, reach what appears to be a full installation of Sonoma.
However, when attempting to boot into the installed OS, the system hangs on a black screen — sometimes right after the Apple logo appears — and after a long delay, it automatically reboots.
I’ve attached a cleaned-up version of my OpenCore boot log, along with my config.plist and full EFI.zip.
My suspicion is that my config.plist is still a mess, since I have many issues editting it — but at least I’m finally getting to the point where it starts to boot.
I’d appreciate any help in identifying what might be wrong, or suggestions on where I should post these questions if this isn’t the appropriate subforum.
Thank you for your time and expertise!
— Patrick
I have tried this EFI, and after multiple attempts and without modifications to it, but to the target disk and resetting NVRAM several times, I have reached the point where MacOS boots and want the setup information.Yes some mess also in this EFI
If you like, backup yours and use this one attached:
if you use it in initial boot menu reset/clear Nvram
then choose your booting icon and click on it with ctrl key pressed and left mouse butto on icon to fix your os booting icon (it useful when you reset Nvram to do one time)
and cross finger because this revisited EFI should work also in Tahoe OS![]()
