Need help with macOS Sequoia on Ryzen 9 9950X (OpenCore Boot Failure)
I am sure any comments about your EFI folder were meant to be constructive, not negative.
I will have a look at this later today.
I have reached a point where I can boot into the installation section for Sonoma, but neither Disk Utility nor the Installer can see USB drives. I had the NVMe SSD drive attached via USB, mostly for convenience to move it to another computer. Once I placed it into the NVMe port, it worked and I am currently doing my first install.
However, I need information on how to set up OpenCore to see the USB ports on a ASUS ROG STRIX X870E-E Gaming WiFi.
If there are instructions regarding this, please let me know where they are located.
Thank you
PF
Hi you should re-check starting from here
In Latest EFI you added stuff you do not need
USB mapping must be done to see your audio and all USB port you use
If your motherboard has USB audio you do not need any kext for it (APPLEAlc i mean) no layout id and similar stuff
You miss then a useful quirk for X670/X870 platform (SetVirtualMap in booter quirk)
Also you have resizebar set to 0, so you must have resizebar on on your motherboard bios setting
