This EFI worked for another user with a very similar board, it is setup so you can add a Fenvi T919 pcie wireless/bluetooth adapter later if you are interested. USB port mapping will need to be done by you.
** Preliminary Build Guide for Asus X670E Gene and Other AM5 Boards **
Also refer to this Outline of the Steps
Supports Big Sur, Monterey and Ventura
14 April 2023: Added OpenCore 0.9.1 EFI Folder See post #5 below for details and EFI folder
NOTE:
If you choose to use the files and information provided in this post, you agree to do your homework to resolve problems and to tailor the configuration for...
