Help, I need a working EFI for my build: Ryzen 9600X, RX 5700XT, Gigabyte B650M D3HP.
aminlight51
AMD Ryzen 9600X
I would really appreciate it if someone would give me a working EFI folder for my build. I tried to build one but it just does not work. Thanks guys
This EFI worked for another user with a very similar board, it is setup so you can add a Fenvi T919 pcie wireless/bluetooth adapter later if you are interested. USB port mapping will need to be done by you.
Really appreciate it. I will test it right away
This EFI worked for another user with a very similar board, it is setup so you can add a Fenvi T919 pcie wireless/bluetooth adapter later if you are interested. USB port mapping will need to be done by you.IMG_1500.jpg
So after testing it unfortunatelly it does not work:
Have a look at this thread/guide.
