macos 15 installation stuck at error
RonaldRaygan
ryzen 5 5600
Hi everyone! Im trying to install macos 15 on my pc, but opencore keeps giving me an error message:
#[EB.WL.PWLFNV|!] Err(0xE) <- RT.GV wake-failure 7C436110-AB2A-4BBB-A880-FE41995C9F82
#[EB.WL.DT|!] Err(0xE) <- EB.WL.PWLFNV
#[EB.WL.DT|!] Err(0xE) <- EB.WL.PWLFRTC
#[EB.LD.OFS|OPEN!] Err(OxE) <"usr\\standalone\\OS.dmg.root_hash">
#[EB.RH.LRH|P!] Err(0xE) <- EB.LD.LF
#[EB.BST.FBS|!] Err(0xE) <- EB.RH.LRH
Here's my configuration:
ryzen 5600
cusu ddr 4 32 gb 3600
wd green 120g
vega 56
msi b550 pro vdh wifi
ryzen 5600
wd green 120g
vega 56
ryzen 5600
wd green 120g
vega 56
Without being able to see your entire EFI folder, which would give everyone a better idea of what you have going, I can tell that you haven't adjusted your Kernel patches to reflect the core count of your CPU. You have a six core CPU, follow the instructions below to learn how to do that using some kind of plist editor.
Also B550 boards require CPUR-SSDT.aml which you are missing, both of these issues will cause the error you currently have. I would not be surprised if once you fix those there are others, if you need more help zip and upload your entire EFI folder.
Reactions: RonaldRaygan
Hello, thanks for your help but i still have that error
Here's my efi folder:
There are four Kernel patches to apply your core counts to, you only changed the first one which will not allow you to boot Sequoia. Edit them all, especially the last one. Clear NVRAM and try again.
