Errormessage Aptiomemoryfix
Keymaster78
Hello!
Have followed this guide: https://vanilla.amd-osx.com/
Everything worked just fine with the guide (except that i had to download one of the exe-files manualy) - however; I get this error when i try to boot from the USB:
OCABC: Found legacy AptioMemoryFix driver
Anyone know what to do? Thank you for your help! :)
My system:
AMD Ryzen 5 2600X
ASUS ROG Strix B450-F
Remove AptioMemoryFix from your config under UEFI -> Drivers
It's not required.
Keymaster78
It's not required.
Excelent!
Thank you! - Now i get to the Clover-bootmenu. After that when i try to choose "install" - I get an white circle....
Keymaster78
I assume you mean OpenCore lol Anyway check your config on this site, https://opencore.slowgeek.com/
Thank you for your reply, so glad to get help :)
Well actually, it was Clover because I got another error on OpenCore. Now I have innstalled OpenCore again, and I guess the missing plist is my problem. I followed your link, but where do I find the plist file that I should upload? (maybe I missed something in the guide)
And when I have an:
AMD Ryzen 5 2600X - Is that 0.5.5, 0.5.6 or 0.5.7
The plist file is in your EFI fodler (config.plist) If you downloaded the most recent version of OC from GitHub then it'll be 0.5.7
