IOG flags 0x3 (0x51)
checks
Ryzen 3 1200
I have a fully working hackintosh 15.5, 15.6beta. I updated the OS to 1.0.5, updated the kexts, disabled the interfering kexts, but I stop at this error. I suspect that the problem is in the video card. Tell me how to get around this problem.
disable AMDRyzenCPUPowerManagement.kext + SMCAMDProcessor.kext
after disable AMDRyzenCPUPowerManagement.kext + SMCAMDProcessor.kext kernel panic
P.S in the end i reflashed my rx460 to rx560, disabled whatevergreen, appleALC and other unnecessary kexts, disabled the first patch in patches and calmly updated from sequoia to tahoe beta2. everything that is needed works. i use apple cinema display, so there are no problems with sound. i don't use wifi and bluetooth.
Build EFI this app winodws https://github.com/lzhoang2801
Соберите EFI это приложение windows https://github.com/lzhoang280
Everything is already assembled by hand, I've been testing it for the third day, everything that needs to be works. If anyone is interested, I'm attaching my EFI folder. Hardware B450M, Ryzen 2 1200, RX460(RX560), when installing add boot-args "-v -amd_no_dgpu_accel", after installation remove "-amd_no_dgpu_accel" and everything works.
  • Tahoe_Beta2.zip
    Tahoe_Beta2.zip
Reactions: Naveed
