Gaetano check this thread, you could find an EFI to startThis is my config (for monterey, since i tried both monterey and sequoia)
thank you i'm checking it out. How can i be sure that my NVRAM is working, or can I emulate it anyway?I need it confirmed that it wasn't just a config issue all along. If it doesn't boot with the current OC release then I'll clean it up and submit a pull request.
@Katanoko1221 are you still using the debug version? Can you upload the log from booting successfully into macOS please.
no need for now, you have to follow that thread nvram is latest of your problem before you have a booting EFIthank you i'm checking it out. How can i be sure that my NVRAM is working, or can I emulate it anyway?
So the issue comes from this part of the log, right?no need for now, you have to follow that thread nvram is latest of your problem before you have a booting EFI
07:473 00:294 AAPL: #[EB|SB:SBGMFNS] x86legacyap.im4m07:488 00:014 AAPL: #[EB|RH:PF] usr\standalone\OS.dmg.root_hash07:502 00:014 AAPL: #[EB|RH:MF] <"usr\\standalone\\OS.dmg.root_hash.x86legacyap.im4m">07:516 00:014 AAPL: #[EB.LD.LF|IN] 0 1 <"usr\\standalone\\OS.dmg.root_hash"> <"0">07:828 00:312 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"usr\\standalone\\OS.dmg.root_hash">07:843 00:014 AAPL: #[EB.RH.LRH|P!] Err(0xE) <- EB.LD.LF07:857 00:014 AAPL: #[EB.BST.FBS|!] Err(0xE) <- EB.RH.LRH07:871 00:014 AAPL: #[EB|LOG:DT] 2025-05-02T12:45:2211:245 03:374 AAPL: #[EB.MM.AKM|!] Err(0xE) <- EB.MM.MKP11:259 00:014 AAPL: #[EB.BST.FBS|MM!] NULL <- EB.MM.AKM 516811:273 00:014 AAPL: #[EB|WL] 0 0 0x01 0x03 19 0x0E11:287 00:013 AAPL: #[EB|STOP]11:301 00:014 AAPL: #[EB|WL] 0 0 0x01 0x03 19 0x0E11:470 00:168 AAPL: #[EB|LOG:EXIT] 2025-05-02T12:45:2621:504 10:034 OC: Boot failed - Aborted21:518 00:013 OCB: StartImage failed - AbortedI already have one, but i was already working with a full offline installer, which gives me that errorIf the Gigabyte X870 Eagle motherboard uses the newer 'Dragon' 2.5GB controller, then LucyRTL8125Ethernet.kext probably won't work. As the newer Realtek 'Dragon' LAN controller can have a different Device-ID compared to the older RTL8125B controllers.
You may need to use a USB to Ethernet adapter, as your WiFi 7 card (Realtek or MediaTek) won't work in macOS.
See this Amazon UK page for a list of USB to Ethernet adapters.
