vm_shared_region_start_adress() failed error
powermint
7
Ryzen 5 4500
hi, i have a trouble with installing macos, when system is booting it shows a lot of errors with
vm_shared_region_start_adress() failed error​
how can i fix it?
What are you using currently?
We can't really offer help if we don't know what you are using. So post a copy of your EFI folder, we can then see what might need fixing.
upd: before this try i had macos on same hardware
Which version of macOS and which bootloader were you previously using on this system?
Try the attached EFI-2, see if this gets you any further in the boot process.
tried it, oc doesnt see "basesystem.dmg"
an "opencore" device appeared in the bios
OpenCore device in Bios, is from me setting an entry in the config.plist for OpenCore to appear in the Bios. This should be set as your priority boot option, i.e. first boot option.
so how to solve this problem?
