GIGABYTE AORUS X570 Master Ryzen 5900x
Mylo
39
5900X
Hi,
I'm currently running my Sonoma 14.4.1 System and would like to update it to Sequoia.
I've updated Open Core to 1.0.2 and all Kext files.
In the Install process I'm getting in to a boot loop and nothing happens. I was able to record the code and it looks like something is wrong with the ACPI?
Any ideas?
Hi,
Any ideas?
It's always best to upload your compressed entire EFI folder because the config.plist only tells part of the story. From what I can see, and if you didn't update your bios, try disabling any bluetooth and wireless kexts and see if that helps. AirportItlwm.kext no longer works in Sequoia, you have to use itlwm.kext with Heliport instead, and bluetooth requirements have also changed. I would also disable any other nonessential kexts including AMDRyzenCPUPowerManagement.kext until you can boot.
