I have an ASRock B650M Pro RS Wifi with BIOS 3.08 and AGESA 1.2.02 and have the issue, that the PC Restarts instead of Shutdown. PC shuts down for a second and then immediately turns on again. But it's not defaulting BIOS settings, so it's not a safe-mode restart.
But sleep works fine.
I tried many different ways to map my USB-Ports. Now I am doing that via SSDT and am pretty sure it's not the USB-config. It looks good to me and all Ports work fine.
I also tried setting up SSDT-FixShutdown. My USB-Hubs are:
\_SB.PCI0.GPP7.UP00.DP60.XH00
\_SB.PCI0.GPP17.XHC0
\_SB.PCI0.GPP17.XHC1
\_SB.PCI0.GPP19.XHC0
They all have an RHUB underneath. In my SSDT I only changed XH00 (because this one had more than 15 ports). I used _STA to disable the RHUB and replace it with my own port configuration as XHUB.
I noticed this behavior basically on all BIOS after 1.30 AS05 and some user on my Github Page reported the same.
Maybe someone has the same issues with B650.
