BigSur beta 4 Legacy
cupecups
14
indonesia
cupecups.github.io
AMD FX 8150
Success run Bigsur beta 4 on my legacy FX
here the spec
  • fx 8150
  • radeon 7850
  • ga-78LMT usb3
  • usb 5.0 BT dongle
  • wifi TPLINK usb
Work?
  • iService
  • sleep shutdown
  • usb port both 2.0/3.0
  • graphics acceleration
  • wifi BT using usb dongle
  • handoff? I don
  • everything almost work (system)
Issue?
  • need 3 times to try boot BigSur cause panic
  • Cmos checksum always error when botting this OS
  • restart pc is take a long time
please don’t tell me about EFi 😅 this only test because I’m using catalina for primary OS
Hello cupecups,
where did you find the patches.plist for AMD FX?
I'm on Catalina 10.15.6 with OC 0.60, so I don't need soembody else EFI.
I only need the patches.plist for AMD FX and nothing else.
Or did you take the patches.plist for Catalina Beta 6?
Greetings from Germany, maclinux1960
Hello cupecups,
yes use beta patched
Hello cupecups,
did you only try Big Sur Beta 4 or the other Beta Versions to?
I loading the Public Beta down, what will take some Days, because a only have
DSL 1 Speed.
Hello cupecups,
DSL 1 Speed.
Yes i use since beta 1
Hello cupecups,
only 1 Question: Did you use VirtualSMC.kext oder FakeSMC.kext for your AMD FX?
All the time I used FakeSMC, but I don't know if I'm forced to use VirtualSMC.kext for BigSur.
In the mean time a downloaded BigSur Beta 1 and the Download for BigSur Beta 4 is almost finish.
Hello cupecups,
I use virtualSMC kext to boot bigsur without additional boot arg
Hello cupecups,
can You share your EFI ? I only come to, if I try to install with USB Stick:
Greeting from Germany, maclinux1960
