Among other issues you are missing from your config.plist any Booter/Mmiowhitelist entries essential to boot. See the attached, USB configuration is going to be wrong so be prepared to try various USB ports and ethernet or wireless/bluetooth its not configured. Those can be added later if you can install.Yes, of course
Okay, good. Did you open disk utility once the installer loads and format your target disk properly?thx, now it works but I have a new error "You may not install to this volume because the computer is missing a firmware partition" when I try to choose a disk
Yes, I tried to format to mac os and got this error. With apfs I have this problem tooOkay, good. Did you open disk utility once the installer loads and format your target disk properly?
I've also erased my HD as macOS Extended Journaled, I let the Installer set the format.Yes, I tried to format to mac os and got this error. With apfs I have this problem too
I think something with EFI because I was installing mac os ventura today and I had not this problemI've also erased my HD as macOS Extended Journaled, I let the Installer set the format.
@Nestovsky were you using the same EFI I uploaded to install Ventura? If so you can always use software update to move to Sonoma.I think something with EFI because I was installing mac os ventura today and I had not this problem
No, I used another EFI which started in Ventura but crashed in sonoma. With both efi I have (You may not install to this volume because the computer is missing a firmware partition)@Nestovsky were you using the same EFI I uploaded to install Ventura? If so you can always use software update to move to Sonoma.
Another option is to try this version of the EFI, it should have ethernet enabled.
The same error is with external disk and sd cardNo, I used another EFI which started in Ventura but crashed in sonoma. With both efi I have (You may not install to this volume because the computer is missing a firmware partition)
That is usually a symptom of improperly mapped USB ports believe it or not.I have the same cpu and motherboard and when I shut down macOS, it immediately restarts
I used USBToolBox to export the USB driver, Hackintool to remove redundant ports, and then exported USBPorts.kext. Restart immediately after shutdown still occursThat is usually a symptom of improperly mapped USB ports believe it or not.
I’m not saying you did it wrong but I’ve read more than my fair share of posts with similar comments only to find errors in the port mapping.The best course for you is to zip and post your EFI for review.I used USBToolBox to export the USB driver, Hackintool to remove redundant ports, and then exported USBPorts.kext. Restart immediately after shutdown still occurs
