It's so slow, barely usable. Typing takes seconds to load single words, and I have Ryzen 7800X3D with 32GB Ram and RTX 4090...how do I fix this? I'm a complete newbie and in vmware I can't turn on 3d acceleration. I just need to use it to sign apps to my apple tv using xcode, but it takes ages to do anything
vmware-resolutionSet
, it doesn't set and instead prints out:Requested resolution: 1920x1080
Effective resolution: 1920x1080
Unable to set resolution
This guide is incredible. Thank you!
One problem though. When I try to set the resolution usingvmware-resolutionSet
Code:Requested resolution: 1920x1080 Effective resolution: 1920x1080 Unable to set resolution
I'm not sure why it would be unable to set. I also tried 1024 768 and it gives me the same "Unable to set resolution"
Does anyone have any idea how to fix this? Nvidia 4000-series GPU, and I don't expect any acceleration, but I never had problems with resolution on macOS 12.5, so this seems unexpected to me.
I already tried everything I could think of like uninstalling/reinstalling VMWare Tools, rebooting, changing settings at the VMWare level, but no luck.
It does seem like I'm unable to access the OpenCore menu though. All I get is a black screen. Otherwise everything works great.
Someone wrote a little program to switch the Hyper-V on and off with the press of a button: https://github.com/ygoe/HyperVSwitchI edited the post and found a way to fix the slowness. It's in the last item which is 8. You should turn off the windows hypervisor and you'll get good performance.
Hey, thanks for the Guide.
but got a problem with the Installation.
After first Reboot i got this Message.. nothing happens since then.
Whats the Problem here ?
I already using the 1.0 4 Core Image.I recommend that you use the VMWare image disk containing version 1.0 of Opencore that was recently added to the tutorial.
From what I've tested here, the older version is having this problem for some reason and I'll remove it from the list.
Try it out and let me know if it works.
I've tested the tool and it doesn't seem to work with Windows 11. I think that because it's a bit old, it only works with older versions.
Tryed it with VMware 17.5 now it works! with 17.0 it doesent.
But now i have a white background, how to fix that?
Works thank you.I've had a few comments here about this:
*** First of all, don't make any changes to the vmware .vmx file. It is recommended that you create a new virtual machine from scratch so that it recreates this file by default and without any changes. *** Use VMWare Workstation Pro version at the link provided in the tutorial. (If you install...forum.amd-osx.com
Depending on the version of macOS you need to switch and find which wallpaper works.
Works thank you.
just the hole VM feels slow :/
I disabled HYPER-V bcs with hyperv the vm dont even run ^^It's slower than using it on the real mac because VMware doesn't have the video compatibility to accelerate all the system's graphics resources. Even so, if you're not using it for graphics, it's quite usable.
However, it is much slower if you leave hyper-v on in windows. Did you turn it off?
