AMD Rayon R7 6800H Install Ventura kernel Panic
redhorse1990
190
11
18
Hello everyone, I have encountered a kernel panic problem for booting up Ventura installation from U flash. Would kindly anybody give me some help?
Brand: Lenovo
Model: Legion slim 7 Gen 7
CPU: AMD Ryzen 7 6800h
GPU: AMD Radeon RX 6600s ( Separate GPU mode)
HDD: Crucial P3 Plus 1TB PCIe Gen4 3D NAND NVMe M.2 SSD
Ram: x2 8GB 3200mhz ddr4
Display: 15.6 1080p 165HZ
  • EFI-3.zip
    EFI-3.zip
The previous issue is resolved. But It comes with another KP following of USBMS identifiers non-unique with a forbidden icon(using the attached EFI). Would anyone kindly give some help?
I don't see a kernel panic in the first images? What exactly is the issue?
Sounds like a USB port configuration issue, from the description in post 2.
Forbidden Sign and message about duplicate ports. Usually caused by OS dropping the USB port that is being used by the macOS installer.
Two options to fix this:
  1. Use a different USB port.
  2. Create a custom USBPorts.kext or UTBMap.kext for your laptop.
Either should fix the issue where the OS drops the USB port, after the initial handover from the Bios. But the second option if the better of the two.
With zxc2689963's newly provided EFI, these KP has been resolved. But it comes with another KP following of USBMS identifiers non-unique with a forbidden icon. It may be related to USB controller of Ryzen 7 6000 has compatibility issues. But I have no idea how it could resolve. Would you kindly provide some help? Here is the created custom UTBMap.kext. Thank you
With zxc2689963's newly provided EFI, these KP has been resolved. But it comes with another KP following of USBMS identifiers non-unique with a forbidden icon. It may be related to USB controller of Ryzen 7 6000 has compatibility issues. But I have no idea how it could resolve. Would you kindly provide some help? Thank you
Is this what your Legion Slim 7 Gen 7 laptop looks like (as in the number and type of USB ports)?
Screenshot 2024-05-02 at 20.35.28.png 2 x USB3 ports on the rear & 2 x Type-C ports on the left side
Your UTBMap.kext/Contents/Info.plist contains the following USB ports with these connector types.
XHC0
HS01 - Internal (255)
HS02 - Internal (255)
XHC1
HS01 & HS02 - USB3 (3)
HS03 - Internal (255)
SS01 & SS02 - USB3 (3)
XHC2
Your UTBMap.kext contains no Type-C ports.
It has 4 x Internal ports, which I believe is 2 x too many. As I would only expect the Bluetooth & Webcam to be connected via Internal USB.
There is a chance your laptop has an internal USB Audio codec, but not a huge chance.
There is also a chance your laptop has som USB LED lighting, but again not a huge chance.
Screenshot 2024-05-02 at 20.46.31.png view of UTBMAp.kext/Contents/Info.plist in ProperTree
So looking at your USB configuration I would say only the 4 x USB3 ports under XHC1 are likely to be correct.
Having one or more ports set incorrectly can cause the issues you are facing regarding the Prohibited Sign error.
View attachment 14043 2 x USB3 ports on the rear & 2 x Type-C ports on the left side
Yes, my Legion Slim 7 looks like this. This is DSDT file I dumped from my laptop. Maybe the UTBMap.kext has some problem. But I think the DSDT is the right configuration.
Have you or anyone else patched your DSDT.aml table?
If not, then it should be correct, unless the writer was stupid and made a bunch of mistakes when creating the table. This is not beyond the realm of possibility.
Have you generated any SSDT’s with the System DSDT.aml, using Corpnewt’s SSDTTime script?
Provide a copy of the EFI folder you are using, the one one your USB installation drive, so we can see what you are using.
Also confirm the following:
  1. The version of macOS you are trying to install, I.e. Monterey, Ventura 13.6.x or Sonoma 14.3.1 or 14.4.1
  2. The make and model of the M.2 drive you are using as the macOS drive.
  3. The make and model of the WiFi/BT card installed in the laptop.
Regarding your UTBMap.kext, you would be best served not using it, as it is wrong and will only cause issues while trying to install macOS. You would be better off using the Kernel > Quirks > XhciPortLimit entry in the config.plist, assuming you are using a version of OpenCore that supports this Quirk (most recent versions do support the quirk).
As you have been at this for sometime I am going to go back over a crucial element that you should have dealt with in order to run macOS Ventura on your laptop.
AMD BIOS Settings​
  • Note: some of these options may not be present in your BIOS, match up as closely as possible but don't be too concerned if some of these options are not available in your BIOS
Disable​
  • Fast Boot
  • Secure Boot
  • Serial/COM Port
  • Parallel Port
  • Compatibility Support Module (CSM)
  • IOMMU
Enable​
  • Above 4G Decoding
  • EHCI/XHCI Hand-off
  • OS type: Other OS
  • SATA Mode: AHCI
As well as the above you may need to set your boot drive to OpenCore.
Your current EFI folder contents look like this.
Here is a revised EFI for you to try.
  • I have cleaned up the EFI sub-folder contents, including removal of the Lenovo folder and SelfHealting file.
  • Added a couple of kexts
  • Removed some unused Tools
  • Cleaned up and edited your config.plist.
This is the contents of the revised EFI folder attached.
I have also attached a copy of the Results folder I generated using your System DSDT.aml and Corpnewt's SSDTTime python script.
The SSDTTime process can be followed by opening the SSDTTime Process text file.
I checked to see if the other SSDT's in your /EFI/OC/ACPI folder were necessary and all seem to be OK.
Remember to use the ResetNvram option from the OC boot screen before you boot with the revised EFI.
Try booting with this revised EFI, see if it gets any further.
Post a photo showing any Verbose text, if it kernel panics.
AMD BIOS Settings​
Disable​
  • Fast Boot
  • Secure Boot
  • Serial/COM Port
  • Parallel Port
  • IOMMU
Enable​
  • Above 4G Decoding
  • OS type: Other OS
  • SATA Mode: AHCI
Thank you for your help. As I am out of town right now. I will try to test it in a few days.
AMD BIOS Settings​
Disable​
  • Fast Boot
  • Secure Boot
  • Serial/COM Port
  • Parallel Port
  • IOMMU
Enable​
  • Above 4G Decoding
  • OS type: Other OS
  • SATA Mode: AHCI
Hi Edhawk, I just tried your provided EFI. It even couldn’t boot from the start with the following error message.(my laptop has an intel WiFi card). Would you help me fix it?
AMD BIOS Settings​
Disable​
  • Fast Boot
  • Secure Boot
  • Serial/COM Port
  • Parallel Port
  • IOMMU
Enable​
  • Above 4G Decoding
  • OS type: Other OS
  • SATA Mode: AHCI
Would you help me check out my issue? Thanks
Which issue? You need to be a bit more precise with your requests.
Where are you with regards installing and running macOS on your Legion Slim 7 Gen 7 laptop?
How have you set the Graphics in your system Bios, have you used the MUX switch to set the AMD Radeon RX 6600s as the main GPU, i.e. turned off the AMD Integrated GPU?
Screenshot 2024-05-21 at 17.27.37.png example of GPU options for Lenovo 7 laptop with MUX switch.
View attachment 14109 example of GPU options for Lenovo 7 laptop with MUX switch.
I checked again, I think I have set for discrete GPU only mode and turns off integrated GPU. But I still have the error posted in #16 ( it even didn't go to the formal boot log ) using you provided EFI.
Hi edhawk, after disabled airport.kext, the previous error resolved. But get a forbidden icon after followings. Would you help me check this issue? Thanks
