I am triplebooting MadOS (Monterey), Windows and Linux (Manjaro) - all separate drives - on an 7800X3D, Gigabyte X670E AORUS MASTER, 32GB DDR5 Kingston FURY RAM, Radeon RX590 Nitro rig.
I could not get it to update to Sonoma, so with some good help from people here I sat out to get a new and improved EFI instead of the mess I had pieced together. I now have a new working EFI that can boot Monterey but I have same irritating issues withit I would like to have sorted before I try an upgrade.
The EFI I used as starting point is attached (thank you to @jan001232 ). The changes I made afterwards are described below:
First of all my Intel AX210 bluetooth does not work even thou it should be supported. I think this is related to USB mapping. See here: https://openintelwireless.github.io/IntelBluetoothFirmware/Troubleshooting.html. Something I have so far not had time to do.
Is there an quick guide for USB mapping?
The other and most annoying problem is that the new OpenCore stopped beeing able to boot Windows and Linux.
Normally OC just boots Windows. No changes made. But now I get an ACPI error if I try. I can boot fine by selecting the drive it is on.
For Linux I have added OpenLinuxBoot.efi and ext4_x64.efi to my config.plist Drivers section and made sure RequestBootVarRouting and LauncherOption are enabled in config.plis. I also enable HideAuxiliary. All as described here: https://dortania.github.io/OpenCore-Multiboot/oc/linux.html#method-a-openlinuxboot
However I get the failed to mount error attached.
Any suggestions to solve this?
