ASUS ROG STRIX GAMING WIFI B650E-F | RYZEN 7 7700X | OC 1.0.6 | RX 6600XT | Intel X520-DA1 |Tahoe 26.2
andyxm715
15
Ryzen 7 7700X
ASUS ROG Strix Gaming WIFI B650E-F
Ryzen 7 7700X | RX 6600XT | 64GB Corsair Vengeance EXPO | Fractal North Mid Tower ATX
Brief History
After building Intel systems for Mac use for many years with my last system being a Z690 i7-12700KF, I decided to move back to AMD which I built from the old Athlon 64 / Phenom ii days.. :geek:
Build
After using Gigabyte boards for many years, I decided to go with ASUS even with their bad reputation at the moment.. BAD luck was on its way to me as my first board was DOA.. great start, but after receiving my replacement everything kicked into gear.
I updated the BIOS to verson 1616 and defaulted the BIOS the only settings I changed was to disable the onboard WIFI, Bluetooth, TPM, CPU PPT limit to 85 and Thermal Limit to 85.
I Created my EFI folder from parts of @CaseySJ @amdeez @Edhawk @Shaneee & Dortania Work.. Many Thanks for your hardwork (y) and also to everyone in the Ryzen 7000 testing thread.. must of spent weeks reading it all.
As I had Monterey 12.6.6 on my Z690 system as I didn't like Ventura (well when I tried it at version 13.2) I decided to keep Monterey on the new system for now.. install was just a easy as an Intel system and completed without problem, only problem I did get when I logged in for the first time was no Audio... this board has USB Audio.. so used the excellent USBMap to map my usb ports and the audio came up.. Happy Days :)
With the CPU at stock settings in BIOS
With the CPU PPT Limit set to 85 & Thermal limit set to 85
My RX6600XT with @Shaneee fix and Powertables added as well... I'm getting
Intel X520-DA1 PCIE Card
What Works
Everything that I used on my Intel system works with my Ryzen system
Fenvi FV-T919 Card removed as no longer works in Sonoma without patches
Intel NIC disabled in BIOS due to crashes
10G Networking with TP-Link TX401 Card - No Longer Used
10G Networking with Intel X520-DA1 Card - (IntelLucy.kext)
iCloud
iMessage
Opencore Updates
Please make sure you...
add your own serial / model details
change the processor core count patches to match yours as the EFI is configured for a 7700X
add your own USB patches
add intel kext if you wish to use the onboard NIC
4th June 2023 - OC 0.9.2
Monterey & Ventura patches active
no USB Port mappings included
1 of the 5 MmioWhitelist activated
13th June 2023 - OC 0.9.3
4 of the 5 MmioWhitelist activate
28th January 2024 - OC 0.9.7
Sonoma patches active
removed intel nic kext as I was getting hangs and crashes (Intel nic is disabled in BIOS)
9th February 2024 - OC 0.9.8
added BIOS Fix aml to ACPI folder to allow boot with BIOS 1807+ (Thanks to Lorys89)
added sbvmm to boot-args
removed AMDRyzenCPUPowerManagement & SMCProcessorAMD from kexts folder
no intel nic kext included
17th March 2024 - OC 0.9.9
as per OC 0.9.8 update with the added updates...
10G network patches applied
changed secure boot to MacPro7,1
7th January 2025- OC 1.0.3v2
total re-write from the start using propertree
All AMD Vanilla patches enabled - CPU patches need to be changed if not using a 7700X
Aquantia (10G Networking) patches included but disabled by default
ACPI patches for Asus B650E-F to allow latest BIOS included but disabled by default
No USBMaps included but XHCIPortLimit enabled - (disable when maps have been completed)
Add your own product details (serial number... etc)
All kexts updated to latest versions
(Working with Sequoia 15.2)
12th December 2025- OC 1.0.6
IntelLucy Kext included for Intel X520, X540, X550 and 82598 Ethernet adapters but disabled by default
ACPI patches for Asus B650E-F to allow up to BIOS 3265 (does not work with later BIOS versions) included but disabled by default
No USBMaps included
(Working with Tahoe 26.2)
View attachment 10829View attachment 10830
Ryzen 7 7700X | RX 6600XT | 64GB Corsair Vengeance EXPO | Fenvi FV-T919 | Fractal North Mid Tower ATX
Brief History
Build
View attachment 10842View attachment 10845
What Works
Bluetooth (use watch to unlock & enter password)
WiFi
Ethernet
iCloud
iMessage
Hi. I'll Try your EFI for my B650E-E
Reactions: dekuyt
I have updated opencore to 0.9.7
I upgraded to Sonoma, so I removed my wifi card - didnt really use it anyway
Been getting werid hangs and slow downs while using the intel nic since Ventura, tried all sorts.. none of them seemed to work to got a cheap realtek pci card and all working great with the RealtekRTL8111.kext
I have updated opencore to 0.9.8
Please find the changes and a copy in post 2
Updated opencore to 0.9.9
Hello! What does BIOS fix actually do? Without it my pcie ax200 doesn't work. It is very strange. My motherboard - asrock x670e pg
The AM5-BIOS-Fix by @Lorys89 that @andyxm715 is using does a number of things. One part of it allows the system to boot if you have updated the bios to the point it enables the Ryzen 8000 processors class.
I was on version 1654, I only update the BIOS if I really need to.. sadly for my board.. version 2214 included a security fix which I wanted to update too.. but the version before 1807 included an update for the latest 8000 series processors which needs the BIOS patch for... otherwise I would of stayed on 1654.
The AM5-BIOS-Fix fby @Lorys89 that @andyxm715 is using does a number of things. One part of it allows the system to boot if you have updated the bios to the point it enables the Ryzen 8000 processors class.
So. My motherboard (Asrock X670E PG Lightning) does support the 8000 series of processors, but there is not a single mention in the changelogs. It seems to be supported with the first version of the BIOS. Now I have the latest version 2.10. It starts without Bios fix, but the PCIE Intel AX200 does not work even with the correct kext. Bios fix somehow fixes this and I wanted to figure out exactly how. And where I can get the source code for this fix.
You can open the SSDT with MaciASL and poke around. As mentioned @Lorys89 is the creator of the SSDT and participates in this forum occasionally
Updated to latest BIOS and the BIOS Fix is still working great.
Hello,
Thanks for your great thread!
But i have problem with your setup and others setups, where EFI for this motherboard.
I already have 4 setups with no luck. So first questin is can i build it with ROG B650E-F + Ryzen 7 9700x? No additional network card or GPU....
I have tried your build, one from github, default one dortania with debug OC and one for 9000 ryzens.... It was most luck with it. Even it was with different ssdt for another motherboard but i get very fast boot. But can't do setup, smth with internet connection or token. (maybe it was no internet, because wrong kext, but setup thinking there is internet?)
Attached config. So, default your file, added serial, -v in boot. Dont changed cpu cores, because it same. So, maybe can help me... :) Thanks. BTW, latest bios
Version 3222 15.37 MB 2025/03/07. I am thinking bios settings is good too. Attaching error....
    config.plist
I have updated opencore to 1.0.6
