how to use OTA to update to Sonoma
silkroadonsale
63
AMD Ryzen 9 5900X Vermeer 3.7GHz 12-Core AM4 Boxed Processor
everytime, I try to use OTA to update Sonoma I got that message and I though I need to disable RetrictEvent kext b/c that's is the cause for using OTA then I can update it but it's unfortunately i can't. so I disable all kext except the required kext to run hackintosh which is Lilu,Virtual, Whatevergreen, USB kext to try again this time i'm still unable to do it either. still getting same error what do I need to do to install Sonoma b/c I don't want to have fresh install. it's sux and pain in the ass. BTW, I have all latest kext and with Latest Opencore verison. if anyone able to figure out please let's me know how to fix it. thanks so much.
doesn't work even add revpatch=sbvmm to boot args. only solution is download entire installer from Apple Store and install. but still it's not OTA at all.
use this mod version , use without any bootarg revpatch=......
And ota update work.
What about the AMD patches? Does it work on Sonoma?
Reactions: Marcyvee
