Shaneee's ASUS ROG STRIX X570-F GAMING - OpenCore EFI
No idea if the GPU is causing any issues. As you haven’t provided any useful information regarding the issues you have encountered.
I am not a mind reader, clairvoyant or omnipotent!
whitesoxbraxton
Hey @Shaneee can you share your working EFI on 0.9.1 for Ventura 13.3.1. I've been having quite a bit of trouble finding a good EFI folder and yours have always worked amazing for me.
whitesoxbraxton
Having trouble with bluetooth, handoff and airdrop using the folder. Tried troubleshooting but not fully understanding what's going on. I've had my fenvi card for years and it's worked but not sure what I need to do to fix it.
whitesoxbraxton
Update: disregard. I've figured out the problem. Total user error, my fenvi card was disconnected smh
piemad2010
Hi I have used your latest EFI folder with Navi adjustment on big sur with no problems thank you , but now I am trying to install Ventura on x570 crosshair viii Ryzen 5950x Gtx1080ti ,as I go in to Opencore reset vram I get a apple picture with no loading bar , can not work it out and have done everything in your guide any help would be appreciated thank you
Did you set the kernel patches to match your core count?
Boot with -v enabled and see where it's hanging. I'd presume it's because of the Nvidia GPU.
You'll need to set your core count again but try this.
