29 Sep Update 3: update to 10.15.7 (from 10.15.6), works as usual.
15 Aug Update 2: update to 10.15.6 (19G2021), works as usual.
17 Jul Update 1: update to 10.15.6 (from 10.15.5), works as usual.
CPU: Ryzen 3950x
GPU: Sapphire Radeon RX 5500XT 4GB
RAM: 32GB of Corsair LPX 3200MHz
Motherboard: Gigabyte Aorus Pro X570 Wifi (have to use bios F11 or F12 to enter recovery. After installation, F21 works fine.)
Audio: ALC1220VB (on Motherboard)
Ethernet: 1G (on Motherboard)
WiFi/BT Card: Broadcom BCM94360CS2 (remove the Intel AX200 and install at the same mini PCIE port)
SMBIOS: iMacPro1,1
Everything works except 1. sleep & 2. mic.
Pretty impressive benchmark in Cinebench r20 without overclocking.
For this build I used the OpenCore Desktop Guide.
OpenCore: 0.5.9
Kexts: Lilu.kext, WhateverGreen.kext, VirtualSMC.kext, SmallTreeIntel82576.kext, AppleALC.kext
Kexts Optional: SMCAMDProcessor.kext, AMDRyzenCPUPowerManagement.kext (I find they are not 100% stable and may cause panic sometime, so I don't use them for long term use)
ACPIs: SSDT-EC-USBX-DESKTOP.aml, SSDT-NVME.aml, SSDT-XHC.aml
Drivers: HfsPlus.efi, OpenCanopy.efi, OpenRuntime.efi
Please use your own SMBIOS generated serial in the config.plist.
CPU: Ryzen 3950x
SMBIOS: iMacPro1,1
OpenCore: 0.5.9
