This is How my EFI is Setup, can I update to Sonoma?
sumeetxolt
10
India
webshade.in
Open Core Version : 9.5
Kexts : All Updated
I'm not sure about latest AMD Patches
System Specs
1CPUAMD Ryzen 5 3600 3.6 GHz 6-Core
2MoboGigabyte B450M DS3H V2
3RAMCorsair Vengeance LPX 16 GB (2x8)
4SSD For FCPWD Green 240 GB 2.5" SSD
5NVMe For OSWD Blue SN550 500 GB M.2-2280 NVME
6HDDToshiba P300 2 TB 3.5"
7HDDToshiba P300 2 TB 3.5"
8GPUGigabyte Radeon RX 560 - 1024 4 GB
9CaseThermaltake S100 Snow Edition
10PSUCorsair VS550 (2018) 550W
11WNAfenvi FV-T919 802.11a/b/g/n/ac WIFI Card
12FansRedgear 120 mm Fans 3-Pack
Kexts : All Updated
System Specs
you don't have latest amd kernel patch yet. so just replace with latest and fix all necessary thing that required then u are ok to update to Sonoma.
I've updated the AMD Patches to the latest available. can I update?
Error shown by OC Auxiliary Tools
NOTE: This version of ocvalidate is only compatible with OpenCore version 0.9.5!
OCS: Missing key InstanceIdentifier, context <Boot>!
OCS: Missing key ConsoleFont, context <Output>!
OCS: Missing key PciIo, context <ProtocolOverrides>!
OCS: Missing key ShimRetainProtocol, context <Quirks>!
Serialisation returns 4 errors!
Completed validating /Volumes/EFI/EFI/OC/config.plist in 2 ms. Found 4 issues requiring attention.
Those errors mean your config.plist is missing the four entries listed, they are expected to be present in the config for OC 0.9.5.
If you compare your config.plist with the 0.9.5 Sample.plist in ProperTree, you can use Find to copy and paste the missing entries to their respective positions in your config.
