Ryzen 7 5700x / Asus b550-XE / Radeon rx 6900xt / fv-t919
jangsangin
cpu : ryzen 7 5700x
m/b : asus b550-xe
memory : g.skill tridentz rgb 3200c14 8*4
graphic card : asus rx6900xt tuf oc
ssd 1 : netac nv7000 2tb
ssd 2 : sabrent rocket 3 1tb
sound : realtek alcs1220a
lan : intel i225-v
wlan : Fenvi t919
cooler : corsair iCUE H150i ELITE LCD Display Liquid CPU Cooler
case : phateks p600s
power : evga supernova 1600t2
Not working
Not show Graphic on About this Mac
sleep
Try this revised and cleaned up config.plist.
  1. I have removed a number of unnecessary entries.
  2. I have added DeviceProperties for your RX 6900 XT GPU.
    1. Screenshot 2023-01-10 at 14.14.03.png DeviceProperties for RX 6900 XT
Try this config.plist and see if it helps detect and activate your RX 6900 XT.
Best to try it out on a spare USB drive.
So, don't replace your current config.plist until you know this config works.
  • config.plist.zip
jangsangin
So, don't replace your current config.plist un'til you know this con'fig worIlltry
Thanks. Ill
    1. View attachment 9441 DeviceProperties for RX 6900 XT
I applied it, but it makes no difference.
jangsangin
My 6900xt device root is PciRoot(0x0)/Pci(0x3,0x1)/Pci(0x0,0x0)/Pci(0x0,0x0)/Pci(0x0,0x0)
Is it irrelevant?
Yes it is very relevant. If you don’t use the correct device path the patches won’t work.
So, you need to change the device path used in the config.plist, to match your graphics card path.
jangsangin
The same goes for changing the path.
