No UI in OpenCore
dewin_prins
Hello,
I have a problem with my build. The problem is that whenever I try to boot to the OpenCore installer all I get is a blinking underscore. I don't know what to do I have ProvideConsoleGop enabled but still no luck.
SYSTEM:
Asrock 970M Pro 3
AMD FX 8350
MSI Geforce GTX 1050 TI
Kingston SSD
I attached my EFI Folder for OpenCore I hope someone can help me....
Your GPU isn't supported on Catalina. You can use High Sierra, but not Mojave or Catalina.
Thank you for your reply! I tried Mac OS High Sierra and still got the same results...
I attached my newly created EFI folder
