Can i install any mac os?
resefsew
Ryzen 5 5600x
RX 5500XT
Prime a520 m-a
if yes then how?
@apriliars3 don't recommend or advise new members to use a Distro, such as the Olarila image. The whole idea behind this site is for people with compatible setups to use the AMD Vanilla guide.
@resefsew your system is a fairly standard AMD setup, look in the Success Stories forum for a system similar to yours. You will probably find a guide and EFI that is compatible with your system..
This one posted by @Moozuki being a prime example. As the thread provides EFI's that work from Big Sur to Ventura on an A520m system.
Make sure you read the whole thread so you know what is happening and what changes were made to the various EFI's. Also what questions other users asked, as you will probably have the same issues/questions.
You should definitely read the OC guide a few times, so you understand the whole process of running macOS on an AMD Hack.
Moozuki
BTW, I've never tested Ventura....
Ok, good to know for future posts.
Moozuki
All copies of macOS were downloaded from the Mac App Store.
Use Corpnewt’s GibmacOS script to download macOS.
You might want to have a look at @Moozuki’s A520m guide/build as he uses the same motherboard. So it would be very similar to the EFI you will need for your system.
