Ryzen 5800x3d x570s kernel panic in IONVMECONTROLLER
bil.vish
Ryzen 5800x3d
MSI X570S Carbon Max WIFI
GPU RX 6800
Samsung 980 pro 1 tb
Samsung 970 evo 500 gb
created usb map
applied the core count patch
i have a kernel panic
and periodically, instead of a kernel panic, another error occurs
I will be glad for any help
Provide a copy of your OpenCore EFI folder, so we can see what you are using and just as importantly what you are not using.
  • First error is NVME related.
  • Second error is USB related, so I would assume your USB configuration is not working correctly.
    • Error is related to USBToolBox, which failed or Timed out.
    • Do you have the companion UTBMap.kext installed in your /OC/Kexts folder and with a corresponding entry in your config.plist?
    • Without this companion kext the USBTooBox.kext does nothing.
bil.vish
1. yes, i used nvmefix
2. yes, it is installed and registered in the config.plist
  • EFI.rar
