Ryzentosh for iOS Development
fermento
Hi, how is going? I’m planning to build a Ryzentosh (mini ITX) which main purpose will be iOS development. Do they think this is possible or it will be too problematic? Someone has a build that use for development?
Regards,
Fer.
You should be aware of that the WatchKit Simulator does not work and even WatchKit Code does not compile at all!
iOS Code seems to work for me.
I have the current XCode version running on my system and hadn't had any problems so far.
Thanks, I like your build config. What does not work? Wifi & BT? What case do you have?
As usual, no sleep, no Wifi. I have the NZXT H210 (without the i) case right now, which is actually really large for an ITX build, but easy to work with.
use usbfixer..
I'm open to suggestions to build my min ITX computer. Which are your preferences about the motherboard? The cpu is going to be a Ryzen 5 3600, unless someone manage to convince me otherwise :)
I could move to a non mini-ITX build if someone shows me a very stable build cause is going to be used for work, but I prefer a mini-ITX.
For mITX I’d probably go with a B550 one since you don’t get much more from X570 on this form factor.
