I would trying reading up on the HDMI issue with MacOS Monterey. If I recall correctly there were some issues with HDMI on the Hackintosh. Uncertain if they have been resolved in later releases of Monterey as I use primarily DisplayPort.
I have used HDMI on both the TV in the garage to ensure the system is working and on the 65 inch 120MHz Samsung in my condo. They both work without a problem. check site
Most notably there is a long standing issue with USB-C display stability on the 6800, 6800 XT and 6900 XT. Even Apple’s own Mac Pro 6000 series GPUs have this problem. The GPU manufacturer of the Apple specific GPUs recommends not using USB-C for display. The same problems occur with Linux systems running AMD 6000 GPUs with USB-C displays.
One thing I haven't tried is resetting NVRAM also I updated to 12.5 using software update. It worked fine. and again on my old 22 inch IPS monitor everything was working fine. (the IPS monitor is connected via HDMI with a HDMI to DVI converter dongle.
Build Spec
  • CPU: AMD Ryzen 9 3900X
  • Motherboard: 4x ASUS ROG STRIX X570-E
  • RAM: 4x Corsair Vengance 16GB 3600MHz
  • GPU: AMD Radeon RX 6950XT
  • Case: NZXT 710
  • M2 NVME: 2x Samsung 980 PRO 2TB
  • Wifi-Bluetooth: Broadcom BCM4360
  • Cooling: Corsair H115i ELITE RGB
  • Bootloader: OC 0.8.5
  • SMBios: MacPro 7,1
ACPI SSDT's - All bypassed for other OS
  • SSDT-HPET.aml (HPET _CRS (Needs _CRS to XCRS Rename))
  • SSDT-PLUG.aml (CPU power management)
  • SSDT-SBRG.aml (Correcting EC, RTC memory & IRQ conflicts)
  • SSDT-SBUS-MCHC.aml (SMBus Support)
  • SSDT-USBX.aml (USB power tables)
  • SSDT-GPU-6950XT.aml (GPU Spoof through bridge)
Kexts
  • Lilu.kext v1.6.2
  • VirtualSMC.kext v1.3.0
  • WhateverGreen.kext v1.6.1
  • AppleALC.kext v1.7.5
  • AirportBrcmFixup.kext v2.1.6
  • SmallTreeIntel82576.kext v1.0
  • LucyRTL8125Ethernet.kext v1.1.0
  • AppleMCEReporterDisabler.kext
  • BlueToolFixup.kext v2.6.4
  • BrcmFirmwareData.kext v2.6.4
  • BrcmPatchRAM3.kext v2.6.4
  • AMDRyzenCPUPowerManagement.kext v0.7.1
  • SMCAMDProcessor.kext
  • RestrictEvents.kext v 1.0.8
  • NVMeFix.kext v1.1.0
  • RadeonSensor.kext v0.3.1
  • SMCRadeonGPU.kext v0.3.1
  • USBMap.kext - ASUS ROG STRIX X570-E with wifi-bluetoth pcie card
BIOS Settings
  • Enter BIOS -> Press Delete -> Enter Setupv1.0
  • Ai Tweaker -> Ai Overclock Tuner -> D.O.C.P.
  • Advanced -> APM Configuration -> Power On By PCIe -> Disabled
  • Boot -> Secure boot -> Key Management -> Clear Secure Boot Keys
IF NOT USING A BROADCOM INTEL-WIFI PCI-E CARD
If you are using internal Intel wifi-bluetooth, use Intel wifi-bluetooth kext
DO NOT USE MY USBMAP.KEXT due to different mapping, this one is only for people who had externtal broadcomwifi-bluetooth pcie card. If you have it into USB3_4 then, change to USB1_2 whatever you have.
IF NOT USING AMD RX 6X50 (XT) SERIES
Remove EFI/OC/ACPI/SSDT-GPU-6950XT.aml and remove it from conflig.plist
IF NOT USING AMD RDN2 GRAPHIC CARD
Remove agdpmod=pikera from bootflags.
IMPORTANT - PATCH INFO FOR SETTING THE CORRECT CORE COUNT FOR YOUR CPU
Core Count patch needs to be modified to boot your system. Find the two algrey - Force cpuid_cores_per_package patches and alter the Replace value only.
Changing BA000000 0000/BA000000 0090* to BA <CoreCount> 0000 0000/BA <CoreCount> 0000 0090* substituting <CoreCount> with the hexadeciamal value matching your physical core count.
CoreCountHexadecimal
6 Core06
8 Core08
12 Core0C
16 Core10
32 Core20
So for example a 6 Core 5600X would result in these replace values, BA 06 0000 0000/BA 06 0000 0090
Or a 12 Core 5900X that I have it setup as standard would result in these replace values, BA 0C 0000 0000/BA 0C 0000 0090
EFI DOWNLOAD
Build Spec
  • RAM: Corsair Vengance
  • Case: NZXT 710
Is this for Ventura?
The 0.8.5 EFI works with the official Ventura release.
Reactions: sass
Reactions: sass
Same EFI works with macOS Ventura 13.1 beta
Are you using the Fenvi T919 for wi-fi and bluetooth? Does continuity camera work?
No I am not. I have tested this feature but it doesn't work. However, I have to admit I don't need it because I have a webcam.
I have the T919. So far everything works but Continuity camera. Apple Watch unlock sometimes works for login, it always does for app install. I had an old broadcom card I tried using but the bluetooth range is abysmal.
Some time ago, i faced this problem too. As far as i can remember, there is a flag from bcmpatch kext that you can set range of yours.
very sad about continuity camera. I have a Logitec Brio too so it's technically not the end of the world. I cant shake the feeling that the rear camera on the iphone 13/14 Pro Max is superior.
also, this was kind of the only feature I was interested in in Ventura.
FWIW I am using a Fenvi T919 with Monterey and my apple watch series 6 unlocks the Hackintosh no problem but my older apple watch series 4 does not.
try as I might, I can't get the old series 4 to unlock even tho it is recognized my macOS.
both watches unlock my iMac Pro and my MBA M1 without issue.
Build Spec
  • Case: NZXT 710
Kexts
  • Lilu.kext v1.6.2
BIOS Settings
6 Core06
8 Core08
12 Core0C
16 Core10
32 Core20
EFI DOWNLOAD
Thanks so much. It´s work but I have same problems. I have gpu 6800 XT, if I remove 6950xt kext what shoult I do?? thanks in advance and excuse me my poor english.
You need to remove SSDT from ACPI folder and from config.plist (ACPI-> Add). The rest is the same.
Build Spec
  • Case: NZXT 710
Kexts
  • Lilu.kext v1.6.2
BIOS Settings
6 Core06
8 Core08
12 Core0C
16 Core10
32 Core20
EFI DOWNLOAD
Massive thanks for this. Seems to have fixed my weird shutdown issues.
Reactions: Pabo
Build Spec
  • Case: NZXT 710
Kexts
  • Lilu.kext v1.6.2
BIOS Settings
6 Core06
8 Core08
12 Core0C
16 Core10
32 Core20
EFI DOWNLOAD
I used your EFI, along with my Platform Info, set my cores, and removed your usb map and the 6950 SSDT, and dropped it onto a stick with a copy of monterey on it. I booted the stick, and just for shits and giggles, decided to see if my 1Tbv drive from my VM would boot (had the same platform info). Well, it did!
So thankyou mate - I have a bit of work to do like mapping my usb ports, etc, but got it to a point now where is sleeps and wakes, and even unlocks with the apple watch (I have a native broadcom mini card which I swapped out with the intel).
FYI my board is an Asus X570 Gaming-E Wifi II, 5900X CPU and 6900X Asus gpu. The rest is the usual fluff like a heap of ram, two nvme's for Win and Mac, and a AQ107 10GBe card sitting atop the tower awaiting installation.
Will this update to Ventura or should I do a fresh install into a new APFS container and migrate my stuff?
I have the same MOBO, and can't for the life of me get Bluetooth/Wifi working. How did you swap out the mini card, which model card did you buy?
