- Sep 24, 2022
- 21
- 0
- 1
- CPU:
- AMD A6-4400M APU with Radeon(tm) HD Graphics
GoodHave a look at Corpnewt’s gibMacOS script.
GitHub - corpnewt/gibMacOS: Py2/py3 script that can download macOS components direct from Apple
Py2/py3 script that can download macOS components direct from Apple - corpnewt/gibMacOSgithub.com
This tutorial/guide might be of help
gibMacOS Tutorial ~ How to Download macOS Directly from Apple
When your Mac is ineligible to download Catalina or Newer macOS versions If your Intel Mac is from approximately 2011/12 or older (see post #2) you won't be able to download Catalina from the Mac App Store. Follow the instructions in these videos to enable the download of Catalina or newer...www.tonymacx86.com
What is the model of the laptop? Does it have an AMD or Intel CPU?
FYI AMD CPU laptop will not work with macOS, especially one from 2014.
An Intel laptop with compatible i3, i5 or i7 CPU and IGPU will work. IIRC Haswell/Broadcom laptops were current in 2014, both of those will run macOS up to Catalina at least, possibly Big Sur. If it has a Celeron CPU then you are wasting your time, as the HD Graphics (IGPU) won't work with macOS even if you can fake the CPU's ID.
To be honest I think your model of laptop based on the CPU is too old to run macOS. Anything beyond 7 years is now really pushing it. I could send you the link for an EFI based on my AMD Ryzen 9 B550 build which you could try that may work with High Sierra, but you’ll need to modify the Kernel > Patches core count settings to 2 cores (according to AMD Vanilla Patch Github) and possibly remove the AMD RX550 dGPU details in the device properties section. But whether it will detect and work with the Radeon HD GPU in your laptop is another matter:i not know model i think
good i think worked for meTo be honest I think your model of laptop based on the CPU is too old to run macOS. Anything beyond 7 years is now really pushing it. I could send you the link for an EFI based on my AMD Ryzen 9 B550 build which you could try that may work with High Sierra, but you’ll need to modify the Kernel > Patches core count settings to 2 cores (according to AMD Vanilla Patch Github) and possibly remove the AMD RX550 dGPU details in the device properties section. But whether it will detect and work with the Radeon HD GPU in your laptop is another matter:
[GUIDE] OC Monterey Gigabyte B550 Vision D + AMD Ryzen 5900X + RX550 + Samsung 1TB 970 Evo Plus
This is an update for Monterey on my existing Gigabyte B550 Vision D build that was originally built for Catalina. COMPONENTS & SPECS Gigabyte B550 Vision D board https://www.amazon.com/dp/B08C9GJ49M/?tag=tonymacx86com-20 Corsair Vengeance RGB RS 16GB 3200MHz DDR4 RAM...www.tonymacx86.com
You can alter the EFI to fit your needs. Follow the guide here to alter your core count to 2 in the EFI/OC/config.plist:i not have a 9600 build...
hm i have clover on usb i instal opencore i think worked for meYou can alter the EFI to fit your needs. Follow the guide here to alter your core count to 2 in the EFI/OC/config.plist
Oh sorry i have patches.plist file in AMD-vanila_master i not know where i found patches.plistYou can alter the EFI to fit your needs. Follow the guide here to alter your core count to 2 in the EFI/OC/config.plist:
Yes... I broke my notebook he power and show me black screen I think my cpu is dead....You can alter the EFI to fit your needs. Follow the guide here to alter your core count to 2 in the EFI/OC/config.plist:
