RTL8111.kext not working after upgrading to Monterey
Cristofer Souza
I'm having problems working my network card after the update it doesn't appear in the settings just in the PCI tab of Hackintool. I've tried several things and I couldn't solve it, I tested all the kexts from the Miaze repository and also from Rehab, not one of them worked.
My Motherboard is a Colorful CVN X570 Gaming PRO V14.
What Device ID does Hackintool > PCIe tab show for your Realtek RTL8118AS-CG ethernet controller?
Does the Realtek RTL8111Ethernet.kext contain the same device ID your controller uses?
If not, you may need to add a fake device-id to your config.plist in order for your Ethernet controller to work with the Realtek kext.
FYI I used AppleI2xx.kext to resolve some of my Realtek NIC issues on Monterey.
Cristofer Souza
How can I defy the Network Card ID?
You have 2 x RTL8186 Ethernet controllers, have you tried both ports? Do they behave the same?
Can you post a screenshot of the whole (fully expanded) PCI device tab, so we can see the ACPI device names for the two controllers.
Cristofer Souza
I have an RTL8111 offboard network card that also behaves the same way.
I'm at work so I get home to check.
Cristofer Souza
Screenshot from my System Preferences.
Screenshot of your Hackintool > PCIe Tab was requested, not a screenshot of your System Information > PCI report.
Similar screenshot as you posted previously, but with the Hackintool app fully expanded to show all the data, it what I asked for, see the example below.
Screenshot 2022-09-21 at 13.55.45.png Example of fully expanded Hackintool > PCIe tab
Cristofer Souza
View attachment 7305 Example of fully expanded Hackintool > PCIe tab
Screenshot.
Fully expanded screenshot?
No! The bottom of the PCIe tab is not fully expanded. Some information is hidden .
Cristofer Souza
03:00.0 10EC 8168 10EC 0123 Disabl Realtek Semiconductor Co., Ltd RTL8111/8168/8411 PCI Express Gigabit Ethernet Con Network controller Ethernet controller 0/BYD3@3/BYS3@0 ethernet PciRoot(0x0)/Pci(0x1,0x2)/Pci(0x0,0x0)/Pci(0x3,0x0)/Pci(0x0,0x0)
