I added a Sounblaster Audigy FX sound card, it no longer detects the sound port on the motherboard and nor the pcie port, do you have any solutions, thank you in advance
Sound blaster sound cards are not supported in macOS. As Creative don't provide drivers for many of their cards for use in macOS. Only the MacPro systems are capable of using a card like this and Creative obviously felt there was no need to provide a driver.
There are some drivers ported from Linux but they do not work with the Audigy FX card.
Yes, I have been working on some optimization for the output sample conversion code, so it’s more lightweight on the cpu and so things like playback at 192 kHz will use less cpu, and I am performing testing right now, it’s looking good so far, so the release will be out once I am done with that...
I had a look at the KX audio driver created by ITzTravelInTime, before I posted the message for you above. The driver states that Audigy cards are not supported and that the driver is being ported to work on old Mac PPC systems (pre-Snow Leopard). That position has not changed from reading the MacRumors Forum page you linked.
It still seems to be a work in progress for the Audigy series of cards on Intel Mac Pro system's and hackintosh's. You have an AMD Hack, so there may be different issues using the driver on your system.
Change log (from the previous PowerPC Driver Release): Improved performance of the sample clipping code (so play back is less cpu-intensive). Fixed a problem that caused poor playback quality on s...
