Who have a config / Clover / Opencore setup with EFI for Asus TUF Gaming A17 based on AMD Rayzen 9 (4000 series) + nvidia//
Help me please
CPU Properties:
CPU Type OctalCore AMD Ryzen 9 4900H
CPU Alias Renoir
CPU Stepping RN-A1
Engineering Sample No
CPUID CPU Name AMD Ryzen 9 4900H with Radeon Graphics
CPUID Revision 00860F01h
CPU VID 1.2188 V
CPU Speed:
CPU Clock 4441.8 MHz
CPU Multiplier 44.5x
CPU FSB 99.8 MHz (original: 100 MHz)
Memory Bus 1597.1 MHz
DRAM:FSB Ratio 48:3
CPU Cache:
L1 Code Cache 32 KB per core
L1 Data Cache 32 KB per core
L2 Cache 512 KB per core (On-Die, ECC, Full-Speed)
L3 Cache 8 MB
Motherboard Properties:
Motherboard ID <DMI>
Motherboard Name Asus TUF Gaming A17 FA706IU Laptop
Chipset Properties:
Motherboard Chipset AMD K17.6 FCH, AMD K17.6 IMC
Memory Timings 22-22-22-52 (CL-RCD-RP-RAS)
Command Rate (CR) 1T
DIMM1: Micron 4ATF1G64HZ-3G2E1 8 GB DDR4-3200 DDR4 SDRAM (24-22-22-52 @ 1600 MHz) (23-22-22-52 @ 1600 MHz) (22-22-22-52 @ 1600 MHz) (21-21-21-49 @ 1527 MHz) (20-20-20-47 @ 1454 MHz) (19-19-19-45 @ 1381 MHz) (18-18-18-42 @ 1309 MHz) (17-17-17-40 @ 1236 MHz) (16-16-16-38 @ 1163 MHz) (15-15-15-35 @ 1090 MHz) (14-14-14-33 @ 1018 MHz) (13-13-13-31 @ 945 MHz) (12-12-12-28 @ 872 MHz) (11-11-11-26 @ 800 MHz) (10-10-10-24 @ 727 MHz)
DIMM2: Micron 4ATF1G64HZ-3G2E1 8 GB DDR4-3200 DDR4 SDRAM (24-22-22-52 @ 1600 MHz) (23-22-22-52 @ 1600 MHz) (22-22-22-52 @ 1600 MHz) (21-21-21-49 @ 1527 MHz) (20-20-20-47 @ 1454 MHz) (19-19-19-45 @ 1381 MHz) (18-18-18-42 @ 1309 MHz) (17-17-17-40 @ 1236 MHz) (16-16-16-38 @ 1163 MHz) (15-15-15-35 @ 1090 MHz) (14-14-14-33 @ 1018 MHz) (13-13-13-31 @ 945 MHz) (12-12-12-28 @ 872 MHz) (11-11-11-26 @ 800 MHz) (10-10-10-24 @ 727 MHz)
BIOS Properties:
System BIOS Date 03/12/2021
Video BIOS Date Unknown
DMI BIOS Version FA706IU.316
Display:
Video Adapter AMD Radeon(TM) Graphics (512 MB)
Video Adapter NVIDIA GeForce GTX 1660 Ti (6 GB)
3D Accelerator AMD Renoir
3D Accelerator nVIDIA GeForce GTX 1660 Ti
Monitor AU Optronics B173HAN04.7 [17.3" LCD]
Battery Properties:
Device Name A32-K55
Manufacturer ASUS
Unique ID ASUS A32-K55
Battery Type Rechargeable Li-Ion
Designed Capacity 47997 mWh
Fully Charged Capacity 39156 mWh
Current Capacity 38759 mWh (99 %)
Battery Voltage 12.419 V
Wear Level 18 %
Power State AC Line
Help me please
CPU Properties:
CPU Alias Renoir
CPU Stepping RN-A1
CPU VID 1.2188 V
CPU Speed:
DRAM:FSB Ratio 48:3
CPU Cache:
L3 Cache 8 MB
Chipset Properties:
BIOS Properties:
Display:
Battery Properties:
Device Name A32-K55
Manufacturer ASUS
Wear Level 18 %
Power State AC Line
