Hey! Need help with that AMD Laptop Ryzen
triniti2290
Who have a config / Clover / Opencore setup with EFI for Asus TUF Gaming A17 based on AMD Rayzen 9 (4000 series) + nvidia//
Help me please
CPU Properties:
CPU Type OctalCore AMD Ryzen 9 4900H
CPU Alias Renoir
CPU Stepping RN-A1
Engineering Sample No
CPUID CPU Name AMD Ryzen 9 4900H with Radeon Graphics
CPUID Revision 00860F01h
CPU VID 1.2188 V
CPU Speed:
CPU Clock 4441.8 MHz
CPU Multiplier 44.5x
CPU FSB 99.8 MHz (original: 100 MHz)
Memory Bus 1597.1 MHz
DRAM:FSB Ratio 48:3
CPU Cache:
L1 Code Cache 32 KB per core
L1 Data Cache 32 KB per core
L2 Cache 512 KB per core (On-Die, ECC, Full-Speed)
L3 Cache 8 MB
Motherboard Properties:
Motherboard ID <DMI>
Motherboard Name Asus TUF Gaming A17 FA706IU Laptop
Chipset Properties:
Motherboard Chipset AMD K17.6 FCH, AMD K17.6 IMC
Memory Timings 22-22-22-52 (CL-RCD-RP-RAS)
Command Rate (CR) 1T
DIMM1: Micron 4ATF1G64HZ-3G2E1 8 GB DDR4-3200 DDR4 SDRAM (24-22-22-52 @ 1600 MHz) (23-22-22-52 @ 1600 MHz) (22-22-22-52 @ 1600 MHz) (21-21-21-49 @ 1527 MHz) (20-20-20-47 @ 1454 MHz) (19-19-19-45 @ 1381 MHz) (18-18-18-42 @ 1309 MHz) (17-17-17-40 @ 1236 MHz) (16-16-16-38 @ 1163 MHz) (15-15-15-35 @ 1090 MHz) (14-14-14-33 @ 1018 MHz) (13-13-13-31 @ 945 MHz) (12-12-12-28 @ 872 MHz) (11-11-11-26 @ 800 MHz) (10-10-10-24 @ 727 MHz)
DIMM2: Micron 4ATF1G64HZ-3G2E1 8 GB DDR4-3200 DDR4 SDRAM (24-22-22-52 @ 1600 MHz) (23-22-22-52 @ 1600 MHz) (22-22-22-52 @ 1600 MHz) (21-21-21-49 @ 1527 MHz) (20-20-20-47 @ 1454 MHz) (19-19-19-45 @ 1381 MHz) (18-18-18-42 @ 1309 MHz) (17-17-17-40 @ 1236 MHz) (16-16-16-38 @ 1163 MHz) (15-15-15-35 @ 1090 MHz) (14-14-14-33 @ 1018 MHz) (13-13-13-31 @ 945 MHz) (12-12-12-28 @ 872 MHz) (11-11-11-26 @ 800 MHz) (10-10-10-24 @ 727 MHz)
BIOS Properties:
System BIOS Date 03/12/2021
Video BIOS Date Unknown
DMI BIOS Version FA706IU.316
Display:
Video Adapter AMD Radeon(TM) Graphics (512 MB)
Video Adapter NVIDIA GeForce GTX 1660 Ti (6 GB)
3D Accelerator AMD Renoir
3D Accelerator nVIDIA GeForce GTX 1660 Ti
Monitor AU Optronics B173HAN04.7 [17.3" LCD]
Battery Properties:
Device Name A32-K55
Manufacturer ASUS
Unique ID ASUS A32-K55
Battery Type Rechargeable Li-Ion
Designed Capacity 47997 mWh
Fully Charged Capacity 39156 mWh
Current Capacity 38759 mWh (99 %)
Battery Voltage 12.419 V
Wear Level 18 %
Power State AC Line
Moozuki
Not supported by any version of macOS.
triniti2290
I managed to start the installation, but only up to more than the middle of the apple, and then I just wait endlessly and there are no errors
You are wasting your time. It won't boot to the installer or allow you to run macOS.
Both GPU's in your laptop are unsupported in macOS.
Moozuki
We are trying to let you know there are no solutions, you would have better luck with intel laptop.
Well that being the case you need to ask your questions on the other forum.
OG Nerd
nvidia cards no longer supported on mac os, so even if you got it running, it would be buggy at best. Trust me, I have same issue with a Ryzen Laptop. The only way would be with a VM. It is what it is unfortunately.
triniti2290
maybe you have a efi with setup? i try run that for tests?
OG Nerd
I do have an efi for Big Sur that might work for Big Sur with no video acceleration I will post for you Wednesday when I get back. If you can get it to work with the nvidia (boot the installer) I will be surprised but I was able to boot a desktop installer with an nvidia card a while back, but no guarantee
xenearz
Don't waste your time on this, exchange your laptop for a supported one.
This should be your starting point https://dortania.github.io/GPU-Buyers-Guide/.
Before making an exchange choice, you can name your laptop model here and we will help you.
triniti2290
Hey) Okay, will wait) Thanks
