Nvidia GT710
pampas
67
7
Spain
Hello, does it still supported in Ventura??
Thanks
No, none of the Kepler Nvidia GPU's are currently supported in Ventura.
They are not natively supported in Monterey either. You have to use the Legacy Nvidia Patcher by Chris1111, for any Kepler Nvidia cards to work in Monterey. It may be the same for Ventura but we will only know if that is possible, if and when a revised Nvidia Patcher is released.
OK thanks a lot for your answer
OK. I can confirm we can update to Ventura with Open Core Legacy Patcher.
you need to add
"amfi_get_out_of_my_way=1"
" ipc_control_port_options=0"
on boot args
Saludos
Reactions: apriliars3
