xxlifesucksxxx
Hi, im xxlifesucksxxx xD.
ive been trying to get a ryzentosh up and going for a week now and it just keeps going wrong everywhere.
specs:
ryzen 5 3600
msi b450 pro carbon
red devil 5700xt
16gb ram
onboard ethernet and wifi/bluetooth
various drives. 840 pro 128 for main windows os, 2tb 970 evo pro for games and installing mac on a wd blue 640gb.
so here is my hang ups. i can install Monterey 12. 4 but of course i cant get internet to work.
if i try to install the latest BigSur it always fails at the [eb exitbs:start]
im using offline installers for both. both are configed roughly the same.
Any advice? :(
Hello and Welcome. If that's where you're getting stuck then it's one or two things. First being that you've not setup the kernel patches for your 6 core CPU. Second being you've not enabled the ProvideCurrentCPUInfo Quirk in the config.
xxlifesucksxxx
Hmmm. I have it set up the same for Monterey.
ProvideCurrentCPUInfo set to true
Patch 0 and 1 set to b806000 0000
Patch 2 is ba006000 0090
dmls
If the EFI folder can be provided, it is a good thing for competent people
ba006000 0090 is wrong for patch #2
It should be ba060000 0090
Notice the '6' is moved one place closer to the beginning, to match the other two patches.
xxlifesucksxxx
The 2 pacth was just a typo. my bad i was on my phone replying.
here is my EFI folder.
Try this revised EFI folder in place of your current one.
I have added an essential SSDT.
Added some kexts
Cleaned up the config.plist, to remove unnecessary entries
Changed a few entries to match the requirements of the OC guide.
Added the OC GUI in place of the picker list.
Added a couple of new and essential Drivers.
Try this and see how you get on.
xxlifesucksxxx
Added some kexts
Same result. If I make a Monterey installer with that same config it boots up. Just not Big Sur. I’ve tried the offline installer and regular. Same thing
I have no idea why the EFI would work with Monterey but Big Sur not boot. It is normally the other way around.
xxlifesucksxxx
Yea, that’s why I turned to here. Main problem with Monterey is my internet because unless I ordered a network card. :/.
