MSI X570-A PRO installed MacOS 12.4 Faild
lpfwork
6
R9 5950X
MSI X570-A PRO installed MacOS 12.4 Faild. But Can be installed Big Sur 11.6.7.
CPU: AMD Ryzen 9 5950X 16-Core Processor
RAM: 64GB
MotherBoard: MSI X570-A Pro
Disk: Samsung 980 1TB
GPU: GIGABYTE RX 6600XT
Is BIOS not supported?
Did you do set the ProvideCurrentCpuInfo quirk in config.plist?
I try to install it on a USB stick. It can work, but does not recognize M2 hard disk and SATA hard disk. PCIe WiFi is not recognized. EFI also uses Big Sur.
Screenshot of installing to SSD
macOS Monterey does not run on MSI 500 boards with BIOS that Zen 3 support.
If you want to use the 5950X with a 6600 XT you either need to use KVM/QEMU to virtualize macOS, or replace the motherboard with an ASUS or Gigabyte.
macOS Monterey 无法在带有 Zen 3 支持的 BIOS 的 MSI 500 主板上运行。
如果你想在 6600 XT 上使用 5950X,你要么需要使用 KVM/QEMU 来虚拟化 macOS,要么将主板更换为华硕或技嘉。
好,谢谢
Can I drive it Boot 6600xt on Big Sur?
The 6600 XT is only supported by Monterey 12.1 and newer
12.4 runs on my MSI B550 Mortar wifi with 5800x and samsug M.2 PM9a1 SSD, and succesfully upgraded to 13beta, some guys use samsung T7 USB HDD to successfully install 12.4 on MSI B550 Mortar wifi with 5600, you can also try SATA SSD on MSI B550 Mortar wifi
