Information Gigabyte X570
jberdan
Ne pas mettre à jour votre BIOS/EFI à la version f36 ou f37a ou f37c car retour en arrière impossible. De plus, ils sont 'boggés'. et votre hackintosh ne démarrera plus, (sauf Windows) Gigabyte averti mais ... aucune réponse ! Certains forums en ont fait part mais ... trop tard pour moi ! J'attends donc une version stable...
Do not update your BIOS/EFI to version f36 or f37a or f37c because rollback is not possible. Moreover, they are 'bogged'. and your hackintosh will no longer start, (except Windows) Gigabyte warned but... no response! Some forums have mentioned it but... too late for me! I'm waiting for a stable version...
Reactions: AMDPUSH
What steps did you follow to try to change the bios?
I am on f36 and all is good. Not sure what caused your issue with F36+?
Thanks for the heads-up! I checked what version I'm on and it's F36c. I do remember issues with later versions but I could always rollback and since everything works I follow the if it ain't broke method. Not being able to rollback would be a big problem. Keep us updated if you can.
