Error updating macOS to Monterey (OTA) B450M
gopidev
Hi, I'm having a problem updating my hackintosh from the OTA update, i have opencore 0.7.8, When selecting the Mac Os Installer in Opencore i get the following error. Thanks!
BOARD: B450M PRO-4F
CPU: Ryzen 5 3400g
GPU: RX 570 8GB
RAM: X2 8GB 3200Mhz DDR4
"LEB.LD.LF|IN101("(nullstring)")("]")
*LEB.B.SBS ISZ] 723512
*CEBIB:SHA]<c35b5Bc39dlcBdDB2Ddf41b446facb27c95a3e016>
*LEB.WL.PWLFNV||] Err(DxE) <- RT.GV wake-failure 7C436110-AB2A-4BBB-AB80-FE41995C9F82
*LEB.WL.DT||] Err(DxE) <- EB.WL.PWLFNV
#LEB.WL.PWLFRTCINONE]
#LEB.WL.DT||] Err(DxE) <- EB.WL.PWLFRTC
#LEB.FS.AGSVHIRU]D4EDBBEB-1F29-4F2A-B5D9-CBDD53FDEE7F
#LEB.FS.AGSVHI11 Ok(0) <- BS.LocHB 964E5B22-6459-11D2-BE39-00A0C9697238
*LEB.FS.AGSVH|GVI!] Err(0x3) 0
#LEB.FS.AGSVHIGVI1] Err(Dx3) 1
#LEB.FS.AGSVHIGVI!] Err(0x3) 2
*LEB.FS.AGSVH]GVI!] Err(0x3) 3
#LEBIFMUFSV] RV D4EDBBEB-1F29-4F2A-85D9-CBOD53FDEE7F Dx00000040
#LEB.LD.LKC|CFG](*\\macOSInstallData\\LockedFiles\\BootFiles\\BootKernelExtensions.kc">
#LEB.LD.LF|IN101("V\macOS Install Data\\Locked Files\\Boot Files\ \BootKernelExtensions.kc") ("O">
#LEBISB:P1 Qx1
#LEBISB:SBGMFNS]j137ap.im4m
#LEBISB:MF1 \\macOS Install Data\\Locked Files\\Boot Files\\BootKernelExtensions.kc.j137ap.im4m
#LEB.LD.LF1IN] D1 ()\macOS Install Data\\Locked Files\ \Boot Files\ \BootKernelExtensions.kc. j137ap.imAm™) ("D>
#LEBISB: MKRN]
#LEB.LD.LKFS|-?10k(0)
*LEB.LD.LKC|-?10k(0)
#LEBIBST:REV1]
#LEBICSR: OUT1 Ox00000040
*LEB.BST.FBS]+]
#LEBIGIP:PHS.11 Boot
#LEB.BST.FBS|ADSZ10
#LEB.BST.FBSIKSSZ]B
#CEBISB: SBGMFNS1 j137ap.im4m
#TEBIRH:PF1usr\standalone\OS.dmg.root_hash
#LEBIRH:MF1<"usr\\standalone\\05.dmg.root_hash.j137ap.imAm">
#LEB.LD.LF|IN] D 1 ‹"usr)\standalone\\05.dmg.root hash"> ("O")
#LEB.LD.DFSIOPEN11Err(DxE)("usr\\standalone\10S.cmg.root_hash">
#LEB.RH.LRHIP11 Err(DxE) <- EB.LD.LF
*LEB.BST.FBS|11 Err (OxE) <- EB.RH.LRH
#LEBILOG:DT12022-05-14T04:15:06
*LEBILOG:EXITBS:START]2022-05-14T04:15:06
Looks like an issue with your EFI setup. Upload your config and I'll check.
Have you disabled the AMD Integrated Vega 11 Graphics?
gopidev
ProvideCurrentCpuInfo is disabled. This should be enabled and you've still got the old patches which aren't compatible with Monterey. See here, https://github.com/AMD-OSX/AMD_Vanilla
The first bug fixed, now a new bug appears that I hadn't seen. This is the code.
apple.xpc. Launchd|2022-05-14 19:46:45.240624 (system/com.apple.pluginkit.pkd [BB1) ‹Notice): service state: xpcproxy
apple.xpc. Launcha|2022-05-14 19:46:45.240641 (system/com.apple.pluginkit.pkd [BB]) ‹Notice›: internal event: SOURCE_ATTACH, code = 0
apple .xpc. Launchd|2022-05-14 19:46:45.248900 (system/com.apple.trustd) (Notice): internal event: WILL_SPAWN, code = B
apple.xpc.Launchd|2022-05-1419:46:45.248910(system/com.apple.trustd)(Notice):servicestate:spawnscheduled
apple.xpc.Launcha|2022-05-1419:46:45.248913(system/com.apple.trustd)(Notice):servicestate:spawning
apple.xpc.launchd|2022-05-1419:46:45.248955(system/com.apple.trustd)(Notice):launching:ipc(mach)
apple.xpc.launchd|2022-05-1419:46:45.251825(system/com.apple.trustd[89])(Notice):xpcproxyspawnedwithpid89
apple.xpc. Launchd|2022-05-14 19:46:45.251850 (system/com.apple.trustd [B91) ‹Notice): internal event: SPAWNED, code = B
apple.xpc.Launchd|2022-05-1419:46:45.251855(system/com.apple.trustd[89])(Notice):servicestate:xpcproxy
apple.xpc.launchd|2022-05-1419:46:45.251894(system/com.apple.pluginkit.pkd[BB])(Notice):servicestate:running
apple.xpc.Launchd|2022-05-1419:46:45.251897(system/com.apple.pluginkit.pkd[88])(Notice):internalevent:INIT,code=B
apple.xpc.Launchd|2022-05-1419:46:45.251902(system/com.apple.pluginkit.pkd[BB1)(Notice):Successfullyspawnedpkd[BB]becauseipc(mach)
apple.xpc.launchal|2022-05-1419:46:45.255034(system)(Warning):failedlookup:name=com.apple.system.opendirectoryd.membership,flags=Bx8,requestor=xpcproxy[89],error=3:Nosuchproce:
apple.xpc. Launchd|2022-05-14 19:46:45.260639 (system) (Warning): failed lookup: name = com.apple. Logd, flags = Bx9, requestor = pkd[8B1, error = 3: No such process
apple.xpc.launchd|2022-05-1419:46:45.260762(system/com.apple.trustd(89])(Notice);servicestate:running
apple.xpc.Launchd|2022-05-1419:46:45.260768(system/com.apple.trustd[89])(Notice):internalevent:INIT,code=B
apple.xpc.Launchd|2822-05-1419:46:45.260774(system/com,apple.trustd[89])(Notice);Successfullyspawnedtrustd[891becauseipc(mach)
apple.xpc.Launchd|2022-05-1419:46:45.267641(system/com.apple.coreservices.launchservicesd[61])(Notice):servicestate:running
.apple.xpc.launchd|2022-05-1419:46:45.267648(system/com.apple.coreservices.launchservicesd[611)(Notice):internalevent:INIT,code=B
•apple.xpc.Launchd|2022-05-1419:46:45.267655(system/com.apple.coreservices.launchservicesd[611)(Notice):Successfullyspawnedlaunchservicesd[611becausespeculative
.apple.xpc. Launchd|2022-05-14 19:46:45.267763 (system/com.apple.webcontentfilter.RecoveryOS (5B1) (Notice): service state: running
apple.xpc.Launchd|2022-05-1419:46:45.267767(system/com.apple.webcontentfilter.RecoveryOS(581)(Notice):internalevent:INIT,code=©
apple.xpc.Launchd|2822-05-1419:46:45.267772(system/com.apple.webcontentfilter.RecoveryOS(58])(Notice):Successfullyspawnedwebfilterctl[58]becausespeculative
.apple.xpc. Launchd|2822-05-14 19:46:45.279832 (system) (Warning): failed lookup: name = com.apple.system.opendirectoryd,membership, flags = Bx8, requestor = dirhelper[6B]. error
= 3: No such proces
.apple.xpc.Launchd|2822-85-1419:46:45.281691(system)<Warning):failedLookup:name
= com.apple.logd, flags = Bx9, requestor = launchservicesdt61], error = 3: No such process
.apple.xpc. Launchd|2022-05-14 19:46:45.289990 (system) (Warning): falled lookup; name = com.apple. logd, flags= Bx9, requestor = trustdt891, error = 3: No such process
.apple.xpc. Launchd|2822-05-14 19:46:45.295319 (system/com.apple.runningboardd) ‹Notice): internal event : WILL_SPAWN, code = e
.apple.xpc.Launcha|2022-05-1419:46:45.295328(system/com.apple.runningboardd)(Notice):servicestate:spawnscheduled
.apple.xpc.launchd|2022-05-1419:46:45.295331(system/com.apple.runningboardd)(Notice):servicestate:spawning
a. apple .xpc. Launchd|2022-05-14 19:46:45.295388 (system/com.apple.runningboardd) (Notice): launching: ipc (mach)
.apple.xpc. Launchdl | 2022-05-14 19:46:45.297131 (system/com.apple.runningboardd [91]) (Notice): xpcproxy spauned with pid 91
.apple.xpc. Launchd|2022-05-14 19:46:45.297151 (system/com.apple.runningboardd [91]) (Notice): internal spawned with pid 91
n.apple.xpc.launchd|2022-05-1419:46:45.297151(system/com.apple.runningboardd[91])(Notice):internalevent:SPAWNED,code=B
m.apple.xpc.Launchd|2022-05-1419:46:45.297156(system/com.apple.runningboardd[911)‹Notice):servicestate:xpcproxy
m.apple.xpc.Launchd|2022-05-1419:46:45.297205(system/com.apple.runningboardd[911)(Notice):internalevent:SOURCE_ATTACH,code=B
m.apple.xpc. Launcha|2022-05-14 19:46:45.3065B0 (system/com.apple.runningboardd [91]) (Notice): service state: running
m.apple.xpc.launchd|2822-05-1419:46:45.306589(system/com.apple.runningboardd[91])(Notice):internalevent:INIT,code=B
m.apple.xpc.Launchd|2022-05-1419:46:45.306602(system/com.apple,runningboardd[91])(Notice):Successfullyspawnedrunningboardd[91]becauseipc(mach)
m.apple.xpc. Launchd|2822-05-14 19:46:45.316849 (system) (Warning): failed Lookup: name = com.apple. logd, flags = Bx9, requestor = runningboarda(91]. error = 3: No such process
m.apple.xpc. Launchd|2022-05-14 19:46:45.323583 (pid/54 [kernelmanagerd]) ‹Notice): uncorking exec source upfront
m.apple.xpc. Launchd |2022-05-14 19:46:45.323597 (pid/54 [kernelmanagerd]) ‹Notice): created
m. apple.xpc. Launchd|2022-05-14 19:46:45.323852 (pid/54 [kernelmanagerd]) (Notice): uncorking domain
i .apple.xpc. Launchd|2022-05-14 19:46:45.325333 (pid/54 [kernelmanagerd]) (Notice): Service stub created for com.apple.CMValidateMovieDataReferenceService
xtLog: Loading FileSet KC(s)
xtLog: Loading Pagable KC from file /System/Library/KernelCollections/BaseSystemKernelExtensions.kc
m.apple.xpc. launchd (2822-05-14 19:46:45.325428 (pla/54 [kermelmanagerd]) (Notlce): Service stub created for com.apple.ColorSyncXPCAgent
m.apple. xpc. launchal(2022-05-14 19:46:45.325434 (pid/54 [kermelmanagerdl) ‹Notice): Service stub created for com.apple.CoreDisplay.XPCService
apple.xpc.Launchd|2022-05-1419:46:45.325443(pld/54[kernelmanagerd])(Notice):Servicestubcreatedforcom.apple.ImageIDXPCService
m.apple.xpc. Launchd|2022-05-14 19:46:45.325469 (pid/54/com.apple.audio.Core-Audto-Driver-Service) (Notice); created the implicit endpoint upfront
apple .xpc. launchd|2022-85-14 19:46:45.325474 (pid/54/com.apple.audio.Core-Audio-Driver-Service) (Notice›: draining messages from com.apple.audio.Core-Audio-Driver-Service
m .apple .xpc. Launcha|2022-05-14 19:46:45.325480 (pid/54 [kernelmanagerd]) (Notice›: Service stub crKextLog: Collection UUID matches with loaded KCs.
ated for com.apple.audio.DriverHelper
am.apple.xpc.Launchd|2022-85-1419:46:45.325491(pid/54[kernelmanagerd])(Notice›:Servicestubcreatedforcom.apple.coremedia,videodecoder
m .apple.xpc. Launchd|2822-05-14 19:46:45.325495 (pid/54 [kernelmanagerd]) (Notice); Service stub created for com.apple.coremedia.videodecoder .zonto
om. apple.xpc. Launchd|2022-05-14 19:46:45.325500 (pld/54 [kernelmanagerd]) (Notice): Service stub created for com,apple.coremedia.videoencoder
om.apple.xpc.Launchd|2022-05-1419:46:45.325505(pid/54[kernelmanagerd])(Notice):Servicestubcreatedforcom.apple.coremedla.videoencoder.zonto
o.apple.xpc. Launchd I2022-05-14 19:46:45.325509 (pid/54 [kernelmanagerd]) ‹Notice›: Service stub created for com,apple.foundation.UserScriptService
om.apple.xpc. Launcha|2022-85-14 19:46:45.326276 (system) (Warning); falled lookup: name = com.apple.system.opendirectoryd.membership, flags = ®xB, requestor = trustdt891, error = 3: No such process
eferred rematching count 1
DG flags Bx3 (Bx51)
om.apple. xpc. Launchd|2822-05-14 19:46:45.329321 (system) (Warning): Pailed lookup; name= com,apple. Logd, flags = Bx9, requestor = recoveryosdt701, error = 3: No such process
generation from SMC report as
om.apple.xpc.launchd|2822-05-1419:46:45.335381(system/com.apple.trustdFLLeteLper)(Notice):Internalevent:WILL_SPANN,code=0
om.apple.xpc.Launchd|2022-05-1419:46:45.335390(system/com.apple.trustdFileHelper)‹Notice):servicestate:spawnscheduled
ho
Try booting with the revised EFI folder attached below.
It has been edited to better reflect the needs and requirements of your 4-core system. I also removed the npci=0x2000 boot argument, as you have the Above 4G Decode option set as 'Auto' in your Bios. The two should not be used at the same time. I disabled the XhciPortLimit quirk, as it doesn't work in Monterey or the later versions of Big Sur. I also removed a number of empty placeholder entries from the config.plist.
The only thing I am really wary about is your use of the AMD-USB-Map.kext. As I don't know if you created this for your system or if you have taken it from someone else's setup. I have left it in the /EIF/OC/Kexts folder, on the off chance you actually created the kext for your system.
See how you get on with this revised EFI.
