(Solved) I can’t able to update my hackintosh to monterey 12.3.1
santosh mareddy
I tried to update it via store but it reboots again to bigsur please help with my problem,sorry for my english
santosh mareddy
this is my efi
santosh mareddy
when i try to update it stucks at apple logo
Are you Hacking a Dell Laptop or the system shown below each post you make?
The config.plist seems to be set for a Dell system.
santosh mareddy
am using it for system not dell
Try this revised EFI, I have removed a few kexts, added an EC SSDT, changed a few entries to better suit your AMD system including updating the Kernel Patches to the latest release for your 12-core CPU.
You have Airportitlwm.kext and Itlwm.kext in your OC/Kexts folder. You shouldn't be using both, one or the other, never both.
santosh mareddy
Without any problem am booting into big sur but when i tried to install monterey it stucks
santosh mareddy
When i tried this method to install monterey its booting back to bigsur
Try my Monterey working build here, it's for a B550 with 5900X. I have modified it with your details above. Put it onto a separate USB stick's EFI partition (copy the whole folder), and select the stick first at bootup, before selecting Monterey installer. It should boot into Monterey.
santosh mareddy
Screenshot 2022-04-06 at 11.13.29 AM.pngafter successfully installing 0.7.4 Opencore EFi Everything is working Fine
