Wanting to install monteray on my thinkcentre
Tkey97
6
Ryzen 5 2600
Hello i have lenovo thinkcentre m720q tiny and i've tryed so many thing and follow the dortanie guide 3 times, even used gibmacos, and still cant install mac os on my central. Can someone help with building the efi folder?
Here is a list of my parts:
CPU - Intel core i3-9100t
Ram - 12gb 2400mhz.
SSD - SKhynix 512gb
HDD - Seagate baracude 1tb.
Ethernet - intel L219-v
Wifi&Bluethoot - AC8265
Audio - Realtech ALC233
GPU - Intel UHD Graphics 630
Im sorry that is not for amd platform, but im trying to make the station as hackintosh to use it on my living room tv. If it's not possiable to make an efi folder on this spec i can provide specs of my amd laptop, but i dont wan't to make him as hackintosh, cuz im traveling and im gaming on it. Thans in advance and I'm sorry again!
Have a look at these Github page, it might have what you are looking for.
What do you mean you used it, but nothing?
Did you copy the EFI linked on that page to a USB pen drive?
What else did you do?
Did you amend it by adding a new Serial Number, MLB, ROM and SystemUUID?
Yes , by i used it and nothing i mean exactly that. I copy it , edit config with custom SMbios and nothing. Boot the installation goes trough installation as good except the timer shows 3 hours and 25min. and the loading bar is almost at end even on start of the installation, till the timer shows 3 mins loading bar goes to the end and everything freeze, mouse stop work, not moving at all.
So you could boot in to OpenCore boot loader and start the installation of macOS, yes? If so that's not nothing.
That could mean your macOS installation files are corrupt or any number of other issues.
Have you set your bios to run macOS? - # Intel Bios settings
How did you create your macOS installer, in Windows, on a real Mac or another hack?
Are you using the macOS Recovery method or the CreateInstallMedia method that provides the full installer on a USB?
Which version of macOS are you trying to install?
Yes ive done every setting in bios from the guide. I made a usb flash drive via rufus methoud on Windows. And i tryed with big sur with cattalina and with monteray.
Did any of the installations you attempted get to the macOS Installation wizard, where you actually started to install macOS on a system drive?
Or did the OC boot process not get you to the Installation wizard?
Did you change the NVRAM > APFS MinDate and MinVersion entries in the config.plist when you tried installing macOS Catalina.?
See this link on the Dortania OC Coffee Lake guide - # APFS MinDate & MinVersion
Did any of the installations you attempted get to the macOS Installation wizard, where you actually started to install macOS on a system drive? Yes, as i told u. The first times it was 50% success. it boots the reinstall mac os installer, i erased the hdd, then created a new one with the partition type and everything, then run the re install mac os till here everything good, but after starting the installation progress the problems comes. First timer and loading bar are buget. Timer shows very long period of time on start like 3-4 hours and some minutes, and after 30 min of the process the timer switch to 3 min left and froze everything. Second im able to move my mouse in the process till the timer shows 3 min, after he switch the time im not able. And 3th problem is that the loading bar is almost on end even on the start. And thats it with Big Sur and with Monteray
Or did the OC boot process not get you to the Installation wizard? Other times , with Catalina and with Big Sur and with Monteray, its not boot , the debugging screen comes and after its end everything ends, or apple logo comes with no loading bar and froze, or with loading bar but froze in the first 10%.
Did you change the NVRAM > APFS MinDate and MinVersion entries in the config.plist when you tried installing macOS Catalina.? Nope i don't saw that in the guide and i don't do it. I will try it today after work or tomorrow , cuz i found a way to get the needed SSDTs with SSDTtime and i manage to get them, and now i can do proper efi.
Just out of the theme. Did i need to delete everything except one tool (don't remember witch one was) from the tool folder. and mostly all of the drivers except 3-4(don't remember now witch are)?
https://drive.google.com/file/d/1NCWtwxIHKsu2Eh-u922t1UiiRbQJaCl2/view?usp=sharing this are the SSDTs that the program scraped for my system.
Post a copy of the OpenCore EFI folder you are using.
