Everything important seems to work!
Build Spec
ACPI SSDT's - All bypassed for other OS
Kexts
What Works
Sound including the case's front headphones 3.5mm port
WiFi / Bluetooth
USB Type C, 3.0 & 2.0 (All ports Mapped & Open)
Sleep & Wake
Power Nap
Hardware Acceleration
AirDrop
iCloud
iMessages
FaceTime
AppleTV
Netflix & Amazon Prime via Safari
Handoff
Continuity
Apple Watch Unlock
BIOS Settings
Config will come later!
I noticed the brakes on the video card, on the screen saver, and it gives out only 82000 on Geekbench 5
Build Spec
Kexts
What Works
WiFi / Bluetooth
Sleep & Wake
Power Nap
AirDrop
iCloud
iMessages
FaceTime
AppleTV
Handoff
Continuity
Apple Watch Unlock
BIOS Settings
- Advanced -> PCI Subsystem Settings -> Above 4G Decoding -> Disabled
- Advanced -> PCI Subsystem Settings -> Re-Size BAR Support -> Disabled
- Advanced -> USB Configuration -> Legacy USB Support -> Auto or Disabled
- Boot -> Boot Configuration -> Fast boot -> Disabled
- Boot -> CSM -> Launch CSM -> Disabled
