AMD RYZEN 9 Ryzen 9 5950x - X570 Ultra -RX6900XT - Monterey Beta 3 - OpenCore 0.7.7
SeoiAleks
12
Everything important seems to work!
Build Spec
ACPI SSDT's
- All bypassed for other OS
Kexts
What Works
Sound including the case's front headphones 3.5mm port
WiFi / Bluetooth
USB Type C, 3.0 & 2.0 (All ports Mapped & Open)
Sleep & Wake
Power Nap
Hardware Acceleration
AirDrop
iCloud
iMessages
FaceTime
AppleTV
Netflix & Amazon Prime via Safari
Handoff
Continuity
Apple Watch Unlock
BIOS Settings
  • Advanced -> PCI Subsystem Settings -> Above 4G Decoding -> Disabled
Config will come later!
I noticed the brakes on the video card, on the screen saver, and it gives out only 82000 on Geekbench 5
Reactions: Shaneee
Hi, why have you to push the Power button for the the shutdown ? have you an powered USB audiointerface ?
What is your hardware specs? Gigabyte Aorus X570 Ultra? Did you had to use broadcom WiFi 802.11n / Bluetooth4.2 card?
Каковы ваши аппаратные характеристики? Gigabyte Aorus X570 Ультра? Вам приходилось использовать карту Broadcom WiFi 802.11n / Bluetooth4.2?
Wifi working standard , Bluetooth shows that it works but in reality it doesn't
Try power down PC after shutdown (unplug power cable or switch power supply off) for 30sec+ and power it back on
Reactions: SeoiAleks
Can you share your EFI please? I am using the same motherboard
I do not even know
If you're having revision 1.0 of your motherboard, I assume it is disabled for you. Since there is a hardware issue with Gigabyte x570 Aorus Ultra that WIFI/bluetooth won't work when ERP is enabled.
How did you solve the brakes? Did you change something at the EFI? Thanks
