Will not boot past "04:187 00:014 AAPL: [EB|#LOG:EXITBS:START] 2022-01-29T23:48:58"
Zafrax
7
Ryzen 5 3600
Motherboard: Gigabyte Aorus B450 Pro Wifi
CPU Ryzen 5 3600
GPU XFX Radeon RX580 8GB
Whenever I try booting using opencore it says
00:000 00:000 AAPL: [EB|#LOG:INIT] 2022-01-29T23:48:54
00:010 00:010 AAPL: [EB|#VERSION] bootbase.efi 422.140.3~2 (Official), built 2020-06-07T17:23:12-0700
00:020 00:010 AAPL: [EB|#BUILD] BUILD-INFO[306]:{"DisplayName":"bootbase.efi","DisplayVersion":"422.140.3~2","RecordUuid":"D49FA16E-32C0-433B-A742-7405C713BE39","BuildTime":"2020-06-07T17:23:12-0700","ProjectName":"efiboot","ProductName":"bootbase.efi","SourceVersion":"422.140.3","BuildVersion":"2","BuildConfiguration":"Release","BuildType":"Official"}
00:030 00:010 AAPL: [EB|#H:IS] 0
00:040 00:010 AAPL: [EB|#WL:MODE] 0
00:051 00:010 AAPL: [EB|#CONFIG:SRC] <default>
00:061 00:010 AAPL: [EB|#CONFIG| 0] boot-save-log : 0x0000000000000002 (0x0000000000000002 < 0xFFFFFFFFFFFFFFFF) <default>
00:071 00:010 AAPL: [EB|#CONFIG| 1] wake-save-log : 0x0000000000000002 (0x0000000000000002 < 0x0000000000000002) <default>
00:081 00:010 AAPL: [EB|#CONFIG| 2] console       : 0x0000000000000001 (0x0000000000000001 < 0x0000000000000001) <default>
00:091 00:010 AAPL: [EB|#CONFIG| 3] serial        : 0x0000000000000000 (0x0000000000000000 < 0x0000000000000000) <default>
00:102 00:010 AAPL: [EB|#CONFIG| 4] embed-log-dt  : 0x0000000000000000 (0x0000000000000000 < 0x0000000000000000) <default>
00:112 00:010 AAPL: [EB|#CONFIG| 5] timestamps    : 0x0000000000000000 (0x0000000000000000 < 0xFFFFFFFFFFFFFFFF) <default>
00:122 00:010 AAPL: [EB|#CONFIG| 6] log-level     : 0x0000000000000001 (0x0000000000000001 & 0x0000000000000001) <default>
00:132 00:010 AAPL: [EB|#CONFIG| 7] breakpoint    : 0x0000000000000000 (0x0000000000000000 & 0x0000000000000000) <default>
00:143 00:010 AAPL: [EB|#CONFIG| 8] kc-read-size  : 0x0000000000100000 (0x0000000000100000 < 0xFFFFFFFFFFFFFFFF) <default>
00:153 00:010 AAPL: [EB|#H:IS] 0
00:163 00:010 AAPL: [EB|#WL|0] 0x01 0x01   0 0x00
00:173 00:010 AAPL: [EB|#BRD:NV] Mac-27AD2F918AE68F61
00:184 00:010 AAPL: [EB|#WL|1] 0x01 0x01   2 0x00
00:200 00:016 AAPL: [EB|`BST:IDT] {
00:211 00:011 AAPL: [EB|`BST:IDT] }
00:221 00:010 AAPL: [EB|#WL|2] 0x01 0x01   3 0x00
00:232 00:010 AAPL: [EB|#WL|3] 0x01 0x01   4 0x00
00:242 00:010 AAPL: [EB|#BRD:NV] Mac-27AD2F918AE68F61
00:252 00:010 AAPL: [EB|#WL|4] 0x01 0x01   5 0x00
00:262 00:010 AAPL: [EB|`H:CHK] BM: 0x0000000000000000
00:272 00:010 AAPL: [EB|`H:CHK] Err(0xE) @ GV boot-signature
00:283 00:010 AAPL: [EB|#WL|5] 0x01 0x01  23 0x0E
00:293 00:010 AAPL: [EB|`H:CPM] Err(0xE), (24, 24) @ GV Persistent-memory-note
00:303 00:010 AAPL: [EB|#SB] 0x0
00:314 00:010 AAPL: [EB|#LIMGP] VenMedia(957932CC-7E8E-433B-8F41-D391EA3C10F8)/MemMap(10:100000000-100001000)/DMG_000000001DB86E9E.dmg/VenMedia(004B07E8-0B9C-427E-B0D4-A466E6E57A62)/HD(Part1,SigC1C39F41-02BF-4DFA-99FE-784538B38D71)
00:324 00:010 AAPL: [EB|#LIMG:FP] \System\Library\CoreServices\boot.efi
00:334 00:010 AAPL: [EB|#LIMG:OPT] ()
00:344 00:010 AAPL: [EB|`B:OBV] BM: +DMG
00:355 00:010 AAPL: [EB|`B:OBV] BM: +ROS
00:365 00:010 AAPL: [EB|#RPS] R?0 P?0 S?0
00:382 00:016 AAPL: [EB|`OPT:LXF] 'LF (\\System\\Library\\CoreServices\\com.apple.Boot.plist)
00:392 00:010 AAPL: [EB|`LD:LF] FIO: 0, DIR: 1, P: \\System\\Library\\CoreServices\\com.apple.Boot.plist, DP: 0
00:408 00:015 AAPL: [EB|`LD:OFS] Err(0xE) @ OPEN (\\System\\Library\\CoreServices\\com.apple.Boot.plist)
00:418 00:010 AAPL: [EB|`OPT:LXF] Err(0xE) @ 'LF
00:434 00:016 AAPL: [EB|`OPT:LXF] 'LF (Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist)
00:444 00:010 AAPL: [EB|`LD:LF] FIO: 0, DIR: 1, P: Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist, DP: 0
00:485 00:040 AAPL: [EB:#KF] ()
00:495 00:010 AAPL: [EB|#MBA:CL] ()
00:505 00:010 AAPL: [EB|#MBA:NV] (-v keepsyms=1 npci=0x2000 debug=0x100 slide=141)
00:515 00:010 AAPL: [EB|#MBA:KF] ()
00:526 00:010 AAPL: [EB|#MBA:OUT] (-v keepsyms=1 npci=0x2000 debug=0x100 slide=141)
00:536 00:010 AAPL: [EB|#LOG:VERBOSE] 2022-01-29T23:48:54
00:546 00:010 AAPL: [EB|`CSR:S] csr-active-config = 0x00000040
00:556 00:010 AAPL: [EB|#OPT:BM] 0x825082
00:566 00:010 AAPL: [EB|`OPT:LXF] 'LF (\\System\\Library\\CoreServices\\PlatformSupport.plist)
00:577 00:010 AAPL: [EB|`LD:LF] FIO: 0, DIR: 1, P: \\System\\Library\\CoreServices\\PlatformSupport.plist, DP: 0
00:612 00:034 AAPL: [EB|#B:VAw]
00:622 00:010 AAPL: [EB|`B:MN] BM: ROS
00:632 00:010 AAPL: [EB|#WL|6] 0x01 0x01  19 0x0E
00:642 00:010 AAPL: [EB|`CS:CSKSD] {
00:653 00:010 AAPL: [EB|`G:CS] } Ok(0)
00:667 00:014 AAPL: [EB|`LD:LF] FIO: 0, DIR: 1, P: <null string>, DP: 1
00:690 00:022 AAPL: [EB|`B:SBS] SZ: 621112
00:710 00:019 AAPL: [EB|#B:SHA] 4f3bba9614aa0dbae1943ab55b83beac7e278986
00:723 00:013 AAPL: [EB|`WLWLFNV] Err(0xE) @ GV wake-failure
00:742 00:018 AAPL: [EB|`WLT] Err(0xE) @ WLWLFNV
00:754 00:012 AAPL: [EB|`WLWLFRTC] ! @ RTC:R
00:767 00:012 AAPL: [EB|`WLT] Err(0xE) @ WLWLFRTC
00:783 00:016 AAPL: [EB|`LD:LKC] BM:R -> (System\Library\PrelinkedKernels\prelinkedkernel)
04:047 03:263 AAPL: [EB|`LD:LKFS] } Ok(0)
04:059 00:011 AAPL: [EB|`LD:LKC] } Ok(0)
04:074 00:014 AAPL: [EB|#FWFM] 0xFFFFFF7F
04:086 00:011 AAPL: [EB|#FWFT] 0xFDAFF066
04:098 00:012 AAPL: [EB|#CSR:OUT] 0x00000040
04:119 00:021 AAPL: [EB|`BST:FBS] {
04:131 00:012 AAPL: [EB|`BST:FBS] BA.ADSZ: 0
04:144 00:012 AAPL: [EB|`BST:FBS] BA.KSDSZ: 0
04:160 00:015 AAPL: [EB|`B:WFDW] Err(0xE), 0 @ LocHB 71B4903C-14EC-42C4-BDC6-CE1449930E49
04:173 00:012 AAPL: [EB|#LOGT] 2022-01-29T23:48:58
I have included my EFI if someone could help me, thanks!
try this EFI and disable 4G if you can.
@Zafrax worked ?
any news ?
Sorry for the late reply, weirdly enough i couldn't get Catalina running with that but when i tried both Catalina and Big Sur it said, " An internet connection is required to install macOS."
Your motherboard uses and Intel GB Ethernet controller. So you need to replace the RealtekRTL8111.kext with IntelMausi.kext for your Ethernet to work.
You also need to remove the Realtek kext and add the Intel kext details to the config.plist, otherwise OpenCore will not inject the kext.
Copy of IntelMausi.kext is attached.
I have now tried that but when I type my wifi password it locks up.
Which WiFi card are you using, a Native Broadcom Apple WiFi/BT card or some other card that requires additional kexts?
I provided a kext for your Ethernet port to work. so why don't you use the Ethernet for the internet connection?
For some reason Ethernet just doesn't connect its a Intel 1211 Gigabit card so it should be supported.
Which version of macOS are you trying to install, Catalina? If yes, then try the SmallTreeIntel82576.kext attached.
If you are looking install macOS Monterey, you need to use the latest beta of the AppleIGB.kext, which I have also attached.
Thankfully I finally got ethernet working but the install crashes right when it says " 15 Minutes Remaining" even though the bar is full, the bar also start at 3/4 full when you start it i did try enabling LegacyEnable, LegacyOverwrite, and WriteFlash but no changes :(
I'll have another look at this later today, to see if I missed anything.
I uploaded the error log right before it hangs if it helps.
Thankfully I finally got it somewhat working, I got it running Catalina but there is some issues. First shutdown/restart don't work even though sleep works fine. Second WiFi still doesn't work :( (some reason Bluetooth works) Lastly when signing into iServices like the main one you sign into from System Preferences work but iMessage and FaceTime don't any ideas? ( I would like to update to Monterey if possible)
