Thank you is works instantaly and nicelyI've updated the SMCRadeonGPU kext to improve iStats compatibility:
https://github.com/aluveitie/RadeonSensor/releases/tag/0.3.1
The RadeonSensor.kext provides the GPU temperature which the RadeonGadget displays in the status bar.
Hi!@Darkpulse That is all the RadeonGadget is designed to do currently. That part is independent of VirtualSMC and can also work in a VM for example.
If you want a complete stats overview, SMCRadeonGPU exports the GPU temp to VirtualSMC. Tools like iStats or Sensei can then read it and display with other stats.
Hi,@luchina Make sure the SMCRadeonGPU.kext is loaded after both the RadeonSensor.kext and VirtualSMC.kext
Which SMBIOS are you using? Which SMC keys are available depends on the SMBIOS.
Perfect, I will test with a new SMBIOS (MacPro7,1) and give you feedback! Thanks.iStats is a bit picky and iMacPro1,1 only uses one of 4 keys I publish the value to. You might have better luck with MacPro7,1
