Non working apps after 12.3 beta 1
savage001
So I have not seen anyone mention anything so it could be just me.
After updating to 12.3 beta 1 I have noticed Google Chrome, GitHub Desktop and Logitech GHub no longer work.
I have tried to remove and reinstall with no luck.
Is anyone else having issues with these apps or others?
Not noticed anything so far. Google Chrome works fine for me. Version 97.0.4692.99 (Official Build) (x86_64)
OG Nerd
No issues here, I use chrome and logi hub with no problem after 12.3 beta.
OG Nerd
(Booted into mac os to make sure.... but yeah, no issues with chrome or logi g hub BUT..... I did notice that Affinity Photo would crash but I was using the previous version and updated it and it works now.
savage001
Ok I’ll post my config later and see if anyone can spot a problem. If not maybe a reinstall is needed. Been a while since I’ve done one of those.
savage001
My clover folder to see if anyone can see anything wrong.
  • CLOVER.zip
SeoiAleks
Моя папка с клевером, чтобы посмотреть, не увидит ли кто что-нибудь не так.
Попробуй предоставить им разрешения в настройках безопасности
savage001
Ty to give them permission in security settings.
I’ll give that a try after work today. I didn’t even think of that thanks.
savage001
Nothing in security settings that is showing me anything is being denied, I did see Logitech ghub still has access. Gatekeeper is also off. I think I need a fresh install.
savage001
Ok so i just booted using OpenCore and all is fine, all apps work.
So it has to be a problem with my Clover config.
  • Archive.zip
OG Nerd
I was about to say that I swapped all my bootloaders to opencore because of weird issues with clover. Glad you got that figured out
savage001
In a follow up to this i have reinstalled 12.2 and all apps are working fine with Clover 5144.
I am now downloading 12.3 B1 to test but i have a time machine backup this time if anything goes wrong.
SeoiAleks
can you test how much the video card scores with 12.3 Monterey in Geekbench 5
